| BKTServer error |
Posted by: WM1KE - 08-02-2012, 03:24 AM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori
- Replies (7)
Hello, All...
I have been experimenting with BKTServer and IC-7000BKT (Full Version).
I am having many problems but I am trying to solve them myself,
One problem that I am having is that the BKTServer is occasionally reporting "Error : 10048". Usually I lose the audio feed at the same time (although I lose the audio a lot).
Can anyone tell me what a 10048 error is or where I should begin debugging?
Thanks, 73
Mike
WM1KE
| Client/Server Operation? |
Posted by: WM1KE - 07-29-2012, 01:19 AM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori
- Replies (3)
Hi, All...
I am currently hospitalized and have set up a fully-licensed version of IC7000BKT at a friend's house. I access the PC that is running BKT by using VNC to access the desktop and EchoLink to feed me the audio. While this works, it is cumbersome.
It appears that there is BKTServer. My questions are:
Is there a BKTClient or does IC7000BKT act as the client?
Is there documentation on how to set up a server/client relationship that provides full rig control and audio?
I have searched for this info but, to be honest, my illness limits my patience.
Thanks, in advance.
Mike WM1KE
| NEW USER TO BKT TIME SYNC |
Posted by: WB9IIV HARRY - 06-19-2012, 10:00 AM - Forum: BktTimeSync
- Replies (1)
I'm a user of JT65A-HF.My main question or comment is while using JT65hf
the timing is critical or the program will not work.I've installed your software BKT for time sync.
At the beginning of using JT65 I tell BKt to sync within 1 hour the time seems to tell me this
Local clock offset was -0.011066 seconds.I hit the re sink again and get this response.
Local clock offset was 0.000966 seconds..I really don't understand whats going on.Can you help me out with a answer that will help this 79 yr old man understand ?
MY OPERATING IS WIN 7 ULTRA RAM 4 GIG 64 BIT OP SYS AMD PROCESSOR 2.80 GHZ
PS: MY HF RIG IS A YAESU FT-950 USING RIGBLASTER ADVANTAGE
THANKS DE WB9IIV - HARRY
| How to localize the program |
Posted by: iz2bkt - 05-26-2012, 12:07 PM - Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori
- No Replies
How to localize the program:
1. Go into install folder ( Ex. C:\IZ2BKT\IC706_BKT Icom CAT Control )
2. Copy the files english.lng to a new file .lng (Ex. spanish.lng)
3. Run BKTLocalize
4. Select the new file created in step 2
5. In the right column write the translated text or leave blank to not translate
6. Save the file by pressing Save and Close
7. Run IC706_BKT Icom CAT Control
8. In TAB Utility select Configure
9. Click on the Change Language button and select the new language
IMPORTANT:
. Do not change the special characters that begin with % or \
. Translated sentences should not be longer than the original
Send me the translated file if you want to share it with others users.
Posted by: iz2bkt - 05-26-2012, 12:02 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori
- No Replies
1. Go into install folder ( Ex. C:\IZ2BKT\IC7000BKT Icom CAT Control )
3. Run BKTLocalize
7. Run IC7000BKT Icom CAT Control
IMPORTANT:
