| Supporto audio |
Posted by: it9hlr - 03-11-2011, 10:36 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori
- Replies (7)
ho appena provato ad installare iul programma sul mio nuovo computer,ma subito in partenza mi esce:
ERRORE NELL'INIZIALIZZAZIONE DEL SUPPORTO AUDIO.
Non so cosa fare per farlo partire.
Ti informo che ancora la radio non è collegata al computer perchè sono in attesa di ricevere il cavetto CT-17 usb, precedentemente usavo la porta seriale.
Con il precedente computer usavo il cavetto rs232 e tutto ha sempre funzionato.
Ho provato a cambiare i parametri audio ma non me lo consente.
Saluti, Salvo it9hlr
| Cannot connect to program |
Posted by: W5KTT - 03-07-2011, 08:03 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori
- Replies (7)
Good Afternoon,
I'm a quadriplegic who was referred to your software by someone at Ham Radio Deluxe, because your software can change tones for T-SQL, and HRD cannot. BKT allows more control via computer (CAT control).
For some reason, when I loaded it, I cannot connect and I'm forced to Offline Mode and therefore cannot change ports to try; but HRD works fine on Com 5, the com port I'm using. HRD is not open though.
Also, the little box that comes up when I first installed BKT7000 where I set the ports/speed no longer comes up. It just says Com5 isn't working, exit or work offline. How can I change them now?
My system is a Dell Laptop, with a CI-V cable that has both ACC plug and 1/8" plug for the radio (I have to unplug the ACC and only use the 1/8" for HRD).
73,
Keith W5KTT
| CATBKT puts the radio in direct transmission |
Posted by: py4xx - 03-04-2011, 03:39 AM - Forum: Yaesu
- Replies (8)
CATBKT installed, but the settings do not match to my FT-897D ... When setting up and open the program, the radio is in direct transmission.
No more setting that I have not tried ...
Any tips please??
RIG: FT-897D
CAT: Made in House
S.O.: Win 7 Ultimate
USB to Serial Adapter: COM4
For use with the BBLOGGER.
Thanks.
| icom 756pro + Catbkt |
Posted by: iz8atp - 03-01-2011, 08:15 PM - Forum: Icom
- Replies (2)
grazie, innanzitutto, per la tua interessante interfaccia.
L'ho collegata con il mio, oramai, vecchio 756 pro e sto testando la nuova versione beta.
Ho riscontrato un problema riguardo all'S-meter, che anche quando stacco l'antenna al mio rtx, segnala S6.
A presto Antonello
| Resizing the Main Program |
Posted by: bill2003 - 02-01-2011, 01:15 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori
- Replies (2)
I would like the facility to resize the main control panel so that it covers the whole of a 1024 x 768 screen format with the Quickset, Audio Recorder and PTT docked to it.
One thing I do find irritating is when I open the program up, the Quickset panel, Audio Recorder and the PTT panels are never where I left them and I have spend time putting them back at the side of the main control screen. It would be good if these postitions could be 'remembered' when the program is closed down at the end of a session.
Othewise, the program is excellent and does the job very well.
Bill - G4ERV
| Hardware Limits on CI-V Command |
Posted by: iz2bkt - 01-29-2011, 03:25 PM - Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori
- No Replies
The communication protocol (CI-V) of transceivers ICOM IC-706 has some limitations hardware:
For all models (IC706 - IC706MKII - IC706MKII/G) :
It is not possible read or write memory names.
It is not possible read or write the subtone value.
It is not possible read the setting of the DUP
For IC706 and IC706MKII :
It is not possible read the S-Meter
It is not possible read the SQL
It is not possible read or write the Attenuator
It is not possible read or write the Preamplificator
It is not possible read or write the AGC
It is not possible read or write the NB
It is not possible read or write the Tone
It is not possible read or write the TSQL
It is not possible read or write the Vox
It is not possible read or write the BKin
It is not possible read or write the Compressor
It is not possible read or write the DUP
It is not possible read or write the Reverse
| Can not sync memory from IC7000BKT to IC7000 |
Posted by: julianar - 01-28-2011, 03:22 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori
- Replies (2)
I'm connected to my IC7000 from my PC using the USB RIGTalk from Wester Radio
When I first bring up IC7000, the "Speed Communication Test in Progress" results in a good sync between the SW and the RTX
Any time I hit Synchronize after that, I get an error saying, "Serial port COM26 not working or communication error"
I have to go OFF LINE and then hit the Synchronize in order to have the SW and RTX synchronize
The BIG problem, is that I can't get the memory to synchronize. I load Bank A with what I want to download to my RTX. I hit synchronize pon the memory screen to load the new memory information to the RTX. I choose "Overwrite RTX" option. I click on "Start." At that point nothing happens. I have left it alone for a long time, but still nothing happens
It appears that once I'm synchronized, the connection is lost and I can never synchronize again without going off-line. In any event, I can never update the data bank on the IC7000
The reason I payed for your software and bought the RIGTalk was to be able to download what I want to the memory banks of the IC7000. I'm considering returning the RIGTalk and asking for a refund on the IC7000BKT donation I made. Right now, I'm very disappointed because I can't do the 1 thing that I want to be able to do.
Please advise.
Jule: KF7LOK
