Yesterday, 07:05 AM
10-19-2026, 03:50 PM
  IC706_BKT Version 4.12.0
Posted by: iz2bkt - 12-23-2012, 03:31 PM - Forum: News / Novità - Replies (1)
IC706_BKT Version 4.12.0 :
-Added BKTClient2 version 2.0.0
BKTClient2 with BKTServer2 allows remote management of RTX via LAN or via Internet.
  IC7000BKT Version 1.19.0
Posted by: iz2bkt - 12-23-2012, 03:29 PM - Forum: News / Novità - Replies (1)
IC7000BKT Version 1.19.0 :
  Maidenhead Grid Locator Display in the GPS screen section
Posted by: W7GJ - 12-10-2012, 07:57 PM - Forum: BktTimeSync - Replies (10)
Further to our previous email, I anxiously look forward to your including a display of the Maidenhead Grid Locator in the section of the display screen related to the GPS-acquired information. The Maidenhead Grid Locator is calculated from the latitude and longitude included in the GPS NMEA sentences. Perhaps the GPS section could be expanded slightly to include the latitude and longitude along with the calculated Maidenhead Grid Locator when the ENABLE GPS box is checked.
Please let me know if I can help you with the calculation of the Maidenhead Grid Locator, although there are many other sources discussing how this is calculated from the current latitude and longitude.
Good luck and please let me know when this new version is available ;-) MNI TNX and VY 73, Lance
  Suggestion: Allow user to set when clock update occurs
Posted by: W6DTW - 11-26-2012, 05:19 PM - Forum: BktTimeSync - Replies (2)
Hello Mauro,
I have been struggling with a clock problem while using JT65-HF and a friend suggested BktTS. In struggling with this clock problem I realize that all time correction utilities will apply the correction at the :00 second point. Of course for JT65, this means that the correction occurs during the start of the receive/transmit period, which might affect the QSO. JT65 QSOs occur from :00 to 0:48 seconds every minute. If BktTS would allow the user to set when the clock update occurs, we could set the update to occur between 0:48 and 0:59 seconds, so that the correction does not occur during the receive/transmit period.
Hope this suggestion is useful to you. Thank you for creating and maintaining this excellent software.
...dtw
  Racal Ra1792
Posted by: IZ4YAB - 11-26-2012, 12:17 AM - Forum: General discussion - Problems - Bugs / Discussioni - Problemi - Errori - Replies (3)
Ciao IZ2BKT, vorrei complimentarmi per l'ottimo programma. Finora tra tutti quelli provati è l'unico che mi permette di comandare via pc un Racal RA1792, per quanto riguarda il cambio di frequenza.
L'RX lo piloto tramite convertitore Prologix USB-GPIB (e visto dal pc come com3) e setto il Catbkt come RA6790GM (via hamlib). A parte che non corrispondono i modi di emissione (ma questo dipende dalle hamlib), c'è modo di poter controllare i filtri di banda del Racal tramite il tuo Catbkt??
Aggingo anche una seconda richiesta: come posso fare per poter sincronizzare il Racal con un FT857D, facendo in modo che il Racal segua gli spostamenti di frequenza dello Yaesu? è possibile farlo con il Catbkt??
Grazie anticipatamente.
Matteo
  IC706_BKT Version 4.11.1
Posted by: iz2bkt - 11-24-2012, 03:24 PM - Forum: News / Novità - Replies (1)
IC706_BKT Version 4.11.0 :
Updated BktClient 1.5.4:
- If you have multiple LAN cards you can specify the local IP address.
- Fixed bug translation.
Updated BktRS232 1.0.5:
  IC7000BKT Version 1.18.1
Posted by: iz2bkt - 11-24-2012, 03:23 PM - Forum: News / Novità - Replies (1)
IC7000BKT Version 1.18.1 :
  la attivazione non funziona
Posted by: IZ0DCK - 11-19-2012, 08:52 AM - Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori - Replies (2)
Salve
Sono Antonio IZ0DCK, a suo tempo registrai IC706BKT ed ottenni la "chiave" di attivazione (un file exe), ora ho dovuto installarlo di nuovo ma la "chiave" non funziona ed il programma mi risulta sempre non registrato, che posso fare?
Antonio IZ0DCK
Posted by: iz2bkt - 11-12-2012, 02:53 PM - Forum: News / Novità - Replies (1)
- Changed the management of external drivers for compatibility with Windows 8.
  IC7000BKT Version 1.18.0
Posted by: iz2bkt - 11-12-2012, 02:51 PM - Forum: News / Novità - Replies (1)
IC7000BKT Version 1.18.0 :
