  Yaesu FT-2000
Posted by: Marco - 10-12-2011, 08:01 AM - Forum: Yaesu - Replies (15)
Ciao IZ2BKT,
ho scaricato dal tuo sito il CATbkt, ma non funziona l'impostazione con il mio FT-2000. Ho un PC Win7. In pratica dal mio FT-2000 è collegato con il microHam e per far funzionare la porta com ho installato il software della microham e con questo programma mi riconosce la COM 4. Un volta lanciato il programma della microHam ho aperto il CATbkt, inserendo la COM 4, ma quest'ultimo non funziona e non riesco a capire come mai....... Mi potresti aiutare? Complimenti per il programma ciaoo 73 de HB9TSU Marco
  Windows 7 and sound
Posted by: rmdefore - 09-24-2011, 11:13 AM - Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori - Replies (4)
I am having a sound problem with my system. I am running windows 7 home premium. I cannot enable the computer sound at all. Do you have any suggestions?
  Scan resume Icom Ic-700
Posted by: kc7ido - 09-16-2011, 04:18 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (1)
When useing the scanner on BKT, when stop the software defaults the radios menu #28 (set mode, other, #28 ) to off. I am thinking a option to default the setting on/off when exit. This really isn't a big issue unless using radio on scan with out BKT back and forth. Then this must be reset every time.
  Memories and setting profile/save function
Posted by: kc7ido - 08-31-2011, 07:09 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (2)
I would like to see a way to save all settings and memories into a single file for setting up "profiles" for rapid reprograming. EX: I could have a "home profile" with all my settings and memories, then switch to a "travel profile" which would contain completely different radio and memories. Great for the "long-haul" or setting different "users" even. Thanks, Keep up the good work ! Big Grin
  IC-706 MKII S-Meter Read
Posted by: sv8ckm - 08-21-2011, 07:16 AM - Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori - Replies (2)
Does IC706_BKT Cat Control for Icom IC-706 supports s-meter read during TX (PO or SWR)?
Thank you & 73s
Fotis - sv8ckm
  Improve remote connection client/server
Posted by: iz2bkt - 08-15-2011, 01:30 PM - Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori - Replies (1)
For a good functioning the network should have a bandwidth of about 150kbps in download and 50kbps for upload.
To improve the communication :
In the program IC706_BKT :
1 - Disable [Polling]
2 - If there are errors in setting, in Utility- >Configuration manually put the value in Latency time ( try with 500 or more )
In BKTServer :
1 - If you use more than one network card, in IP put the IP address of the network card to use.
2 - In Audio Stream Configuration use low values of bits/sample and sample/sec, increasing the Buffers increases the delay of listening to the audio.
  Auto Power OFF
Posted by: ct1eky - 08-15-2011, 01:14 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (3)
the program has a funtion in the SET MODE folder to "Set the power-off period for automatic shutdown".
The question is how this function really works and if is possible to get the RAdio "power-on" using the software. This will be great for remote operation of the transceiver through the internet.
Pedro
Posted by: iz2bkt - 08-15-2011, 01:14 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - No Replies
The transceiver Icom IC-7000 has many commands CI-V and on a slow connection may cause delays and false indications.
In the program IC7000BKT :
In BKTServer :
  IC7000BKT Version 1.15.1
Posted by: iz2bkt - 08-13-2011, 01:00 PM - Forum: News / Novità - Replies (1)
IC7000BKT Version 1.15.1 :
- Removed bug on displaying PTT, AudioRecorder and QuickSet.
  Problems with Quickset
Posted by: wb8nbi - 07-14-2011, 05:11 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (3)
When I try to use quickset the program gets very unstable. The Sql and RF gain bounce up and down I have to close program to get it back. Another question is their a way to disable Quickset and PTT and remove them from computer screen?
