  BktTimeSync keeps shutting down.
Posted by: wa4pgm - 07-04-2016, 07:49 PM - Forum: BktTimeSync - Replies (2)
I am trying to setup BKTTimeSync to work with Pharos GPS-360 but I keep getting the popup error that "bkttimesync has encountered a problem and needs to close.
The GPS-360 came with Microsoft Streets and Trips and works fine with it.
Any ideas?
Windows XP
BKTTimeSync 1.7.0
Kyle
  elad fdm duo
Posted by: ik5sre - 06-05-2016, 07:02 AM - Forum: Other / Altri - Replies (2)
vi volevo informare che per utilizzare catbkt e bbloger con elad fdm duo si deve impostare il programma con radio del tipo kenwood ts 480,com 3 38400
8,1,N,RTS OFF,DTR OFF
73 da IK5SRE Francesco
  Ic7100 bktremote server wrong password message
Posted by: VE5RS - 06-03-2016, 10:59 PM - Forum: BktRemote Suite - Replies (2)
Hello
I am trying to run bktremote and when I try to connect
I get a wrong password message on the bkt remote server
73 ve5rs
  GPS Time Not valid?
Posted by: wa3lbi - 05-31-2016, 01:44 AM - Forum: BktTimeSync - Replies (3)
love the program and was having no problem until recently.
I see that my notification says "GPS time not valid"
i Listen to WWV and the clock is right time?
I see that my GPSDO is also 10.00000 MHz from the GPS source ( Trimble Thunderbolt)
Any ideas?
best 73 Jim
  ic7000bkt & windows 10
Posted by: G1YIJ - 05-13-2016, 07:46 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (2)
Has anybody had any success installing IC7000BKT on windows 10? Had full version running fine on windows 7 but after a major system crash I have now purchased a machine with windows 10, sadly I cannot open the programme at all. First install was working fine but then added registration key. That's when things went wrong, double click on programme icon.....nothing happens at all. Tried a re install, same.
  FT950 - problema cat bblogger/catbkt
Posted by: iw2dqe - 04-25-2016, 12:55 AM - Forum: Yaesu - Replies (5)
Buongiorno,
uso come programma di log l'ottimo bblogger e adesso volevo utilizzarlo con la cat del mio yaesu ft950, premetto che come modi digitali utilizzo l'interfaccia usb di IW9GTD completa di cat e come sistema operativo del pc utilizzo windows 10.
Seguendo le istruzioni e leggendo in vari post per utilizzare bblogger devo scaricare il prg.catbkt, configurarlo e poi aprire bblogger e mettere la spunta sulla voce "multi rig catbkt".
Ho scaricato il programma CATBKT , settato, funziona bene. apro bblogger e metto la spunta richiesta e cliccando su uno spot mi cambia frequenza, il problema che poi passo a BBTERM per poter utilizzare i modi digitali e non trasmette perche dice "failed to open the com port ".
sicuramente è perchè la porta viene già utilizzata da catbkt, come posso ovviare a questo problema? Chi mi può aiutare a risolvere?
Grazie e 73 da Giancarlo IW2DQE
  Problema di installazione
Posted by: IK1XVO - 04-16-2016, 06:56 AM - Forum: General discussion - Problems - Bugs / Discussioni - Problemi - Errori - Replies (2)
Ciao Mauro ho dovuto reinstallare il tuo prg Catbkt per il mio icom pro 3.
L'installazione non é andata a buon fine perché il setup non é riuscito ad installare:
C:\WINDOWS\SYSTEM32\CATBKT EXTENSION.DLL.
Grazie per eventuali suggerimenti.
  Audio problem
Posted by: kd2om - 04-12-2016, 08:26 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (3)
I have installed the server software, as well as the radio control software. As long as I leave the VoIP software disabled, I can hear audio from the transceiver when using the remote software on a PC. If I enable the VoIP software I can't hear audio nor can I talk over the radio. I also can not hear audio on the Android version of the remote software.
I am just using the USB cable for both audio and control. Must I use an audio cable from the radio to the PC where the server is?
Steve KD2OM
  catbkt e flex 1500 sdr
Posted by: ik5sre - 04-10-2016, 03:48 PM - Forum: Other / Altri - Replies (16)
-Ciao
utilizzo un flex 1500 e bblogger e stavo cercando un programma che mi permettesse di poter far riconoscere a bblogger automaticamente la frequenza e modo di emissione quando registro un nuovo qso.
Ho provato a installare catbkt ed ho trovato tra le opzioni che dovrebbe funzionare sia con flex 1000 che le versioni 6000,pero' non riesco a farlo funzionare col mio 1500
Non vorrei che magari possa dipendere dal fatto che il collegamento tra radio e pc e' fatto via usb creando una porta seriale virtuale,mentre forse il programma e' fatto per collegare a una porta seriale reale.
mi puoi dare qualche dritta?
  where can i find de DV memories??????
Posted by: Herjo - 02-16-2016, 06:01 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (1)
I can't find the memories for de DV operation
I can't also the configuration for the DV operation.
so, there is a rpt list for the DV (d-STAR) operation, but in de software IC7100BKT, I CANNOT FIND IT.
Can you help me?
greetings PE1MSU
