  How to localize the program
Posted by: iz2bkt - 12-14-2015, 05:04 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - No Replies
How to localize the program:
1. Go into install folder ( Ex. C:\IZ2BKT\IC7100BKT Icom CAT Control )
2. Copy the files english.lng to a new file .lng (Ex. spanish.lng)
3. Run BKTLocalize
4. Select the new file created in step 2
5. In the right column write the translated text or leave blank to not translate
6. Save the file by pressing Save and Close
7. Run IC7100BKT Icom CAT Control
8. In TAB Utility select Configure
9. Click on the Change Language button and select the new language
IMPORTANT:
. Do not change the special characters that begin with % or \
. Translated sentences should not be longer than the original
Send me the translated file if you want to share it with others users.
  IC7100BKT Version 1.8.x
Posted by: iz2bkt - 12-13-2015, 05:38 PM - Forum: News / Novità - No Replies
Is available for download IC7100BKT:
Version 1.8.0 : Added automatic call on CW in the function AutoCQ
Version 1.8.1 : Support BktExtension 1.21.0
Version 1.8.2 : View the version in use (Free, Full or Trial)
Version 1.8.3 : Correct filter settings when changing band
Version 1.8.4 : New version 1.0.1 of OnAir - Correct link to the forum
  Low audio signal
Posted by: kxrist - 11-26-2015, 07:18 AM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - No Replies
I registered and use the program very often. What i experienced so far while connecting with the remote client is that the volume level of audio streamed through the network is very low. I am able to use only speex codec. Is there any other codec i should install to improve the audio level.
Sy1bmo
  Modi digitali
Posted by: iz2dhp - 11-07-2015, 03:14 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (2)
Ciao a tutti, mi sapete indicare quale software usare con IC7100 per trasmettere e decodificare i modi digitali? Possibilmente dove bastano pochi clic e funziona tutto :lol:
grazie Nicola
  VFO A VFO B E SPLIT
Posted by: IK1XVO - 10-31-2015, 01:38 PM - Forum: Icom - Replies (6)
utilizzo BBlogger da diversi anni ed ora sto provando il tuo programma per comandare da pc il mio Icom pro 3.
Non riesco però a far funzionare i tastini del vfo A o B e dello split.
Cosa devo fare?.
73' de IK1XVO Marco
  FT-3000 comandi RX/TX
Posted by: it9hlr - 10-30-2015, 05:36 PM - Forum: Yaesu - Replies (20)
mi rivolgo in particolare a Mauro, autore del programma, per segnalare un funzionamento secondo me anomalo.
Se riduco il programma ad icona, non lo tengo in primo piano o uso l'opzione della barra mini, in questi casi mi azzera il valore dei comendi RX/TX.
E' possibile risolvere il problema?
  Logger32
Posted by: kxrist - 10-29-2015, 09:01 AM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (4)
I have a problem using logger32 along with 7100bkt software due to obvious reasons.
I want to have control over icom with logger 32 and 7100bkt simultaneously which cannot be done for the moment because they share the same serial port.
Is there any alternative ???
thx..
  Can not register software, CAPTCHA will not work
Posted by: johnsloa - 10-26-2015, 06:10 AM - Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori - Replies (2)
Hi
I have tried submitting the captcha on the registration page for over an hour but the captcha will not accept what I type in as the correct "word"!!!
Please send me the registration info (key) as I can not complete the online form!
I really like to look of the software!
Thank you so very much!
John
Posted by: iz2bkt - 10-24-2015, 09:23 AM - Forum: General discussion - Problems - Bugs / Discussioni - Problemi - Errori - Replies (21)
In CatBkt version 1.9.0 or later is available the Custom Key: programmable buttons with custom commands for your rtx.
Click right mouse button on the Custom Key to program and enter a description of the command and the command you want.
Commands must be complete with preamble and closure and written in hexadecimal.
Here is an example for an Icom TRANSCEIVER to implement Swap VFO:
[Image: Icom_swap_vfo.png]
Use your owner's manual for information about rtx CAT commands supported.
  IC7000BKT - PTT
Posted by: herbpk - 10-02-2015, 01:26 AM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (2)
I am running the new version 1.28.1 and I am noticing several anomolies which I don't understand.
1) When I energize the 1750 Hz push-button on the PTT: say I push it for one second to trip a repeater, after about a second later, the IC7000BKT program goes into PTT mode AGAIN, for about 1 - 2 seconds before it auto releases tx. I have no idea why or what is going on. Even on other bands / modes, on SSB, simply pushing 1750 HZ and releasing, I see a one - two second delay / no tx and then a one - two second period that sends the radio into transmit. I don't remember this from previous, what is going on? Why the delay and why the trip into radio transmit?
2) Despite everything, I cannot from the program push the autotune button and get the radio to "turn off" the "tune" light on the radio. If I energize "auto-tune" on the IC7000BKT- PTT control, the radio puts the outboard tuner (LDG IT-100) into tuning correctly, and tunes. But if I push the autotune button again, I expect the radio to "turn-off" the tuner and the tune light on the IC 7000 to go dark. It does not work this way, the IC7000BKT does not turn the tuner "off" as does hitting the "tune call" button on the mircophone does. Audio / Interface is through USB Signallink
Any explanation on these items would be much appreciated.
Herb
