  BktTimeSync Version 1.8.2
Posted by: iz2bkt - 02-07-2017, 03:30 PM - Forum: BktTimeSync - No Replies
Is available for download:
BktTimeSync Version 1.8.2:
- Added Sync Now from icon in system tray
http://www.maniaradio.it
  Encountered an improper argument
Posted by: herbpk - 01-05-2017, 01:52 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (2)
Hello:
I "updated" to the latest version and I have been experiencing program crashes since.
If I open the program with the IC-7000 in operation, I get "Error in the initialization of audio support".
When I acknowledge the error, an audio setting dialog box opens but when I check
"enable audio", I get the same error again. The other areas are not available for any
data input. Closing, the program crashes.
If I try to open the program from the start menu (as alternative to the desktop shortcut) I
get an alternate box stating "encountered improper argument" . I can close the program from here
without a complete "crash" but still no IC7000BKT program.
Anyone have any ideas?
herb
  librerie HAMLIB - significato di rigctld
Posted by: cerrotta - 01-03-2017, 07:25 PM - Forum: General discussion - Problems - Bugs / Discussioni - Problemi - Errori - Replies (2)
E' normale questo funzionamento sotto WIN 10 :
C:\Users\PC>rigctld "qui il prompt DOS si blocca, si sblocca con ^C" A cosa serve questo comando e se è corretto che si blocca ?
C:\Users\PC>
C:\Users\PC>rigctl -m 229 -r com1 " Elecraft K3 RIG"
Rig command: f
Frequency: 17074350 " qui legge correttamente la frequenza del k3"
Rig command:^C
C:\Users\PC>
C:\Users\PC>rigctl -m 2 " questo comando l' ho trovato nei doc di HAM LIB ma non ho capito bene a cosa serve"
rig_open: error = IO error
C:\Users\PC>
Scasami, queste domande sono finalizzate a capire qualcosa di HAMLIB atteso che vorrei compilare LInrad cosi' come specificato in questo articolo " <!-- m --><a class="postlink" href="http://destevez.net/2016/01/using-linrad-as-a-panadapter">http://destevez.net/2016/01/using-linra ... panadapter</a><!-- m -->"
Giacobbe@ic8fax
  CatBkt Version 1.11.x
Posted by: it9hlr - 01-02-2017, 06:37 PM - Forum: News / Novità - Replies (3)
dove posso leggere quali novità sono state apportate all'ultima versione?
Le ho perse anche questa volta.
Saluti, Salvo it9hlr
Posted by: iz2bkt - 01-02-2017, 08:44 AM - Forum: News / Novità - No Replies
Version 1.11.0 : Including new HamLib 3.1
Download from http://www.maniaradio.it/en/catbkten_download.html
HamLib Version 3.1 : the major changes in this release include:
* Fix kenwood_set_mode for ts590s and mode CW, RTTY or AM.
Tks Tom, DL1JBE
* Proper IPV6 and dual stack networking. Bill, G4WJS
* Add a new command line option '--no-restore-ai' ('-n') to rigctl. Bill, G4WJS
* Fix missing PKTUSB mode setting code for FT-817 & FT-897. Bill, G4WJS
* New Prosistel rotor backend from IZ7CRX
* Install daemon man files to man1. Nate, N0NB
* Migrate from libusb-0.1 to libusb-1.0. Stephane, F8CFE
* Added support for Icom IC-2730. robinolejnik
* Added support for the Icom IC-7300. Mike, W9MDB
* Add send_morse to icom rigs. Mike, W9MDB
* added instructions how to compile on OSX. DH1TW
* New Perseus model. Stephane, F8CFE
* Added Lua binding and demo script. Ervin, HA2OS
* Added test to support Flex 6300. Bill, KB4AAA
* Many bug fixes and feature enhancements to the code base.
See the Git commit log for complete details.
  ic7300 catbkt
Posted by: sandro - 12-24-2016, 08:47 AM - Forum: Icom - Replies (7)
complimenti per il tuoi lavori
ho installato il tuo catbkt volendolo usare con bblogger ma non mi commuta la frequenza sulla radio certamente non e' stato settato bene cosa devo fare???
  Still waiting on key for Icom 706 mkiig
Posted by: Italian907 - 12-23-2016, 04:53 PM - Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori - Replies (2)
Still waiting on my key............... <!-- e --><a href="mailto:lt907@zoominternet.net">lt907@zoominternet.net</a><!-- e -->
  TS480 e remoterig
Posted by: iz4ftd - 12-11-2016, 07:31 AM - Forum: Keenwood - Replies (2)
Buongiorno,
utilizzo CatBkt da diverso tempo in locale con TS2000 e adattatore USB/232, da qualche tempo ho installato una remote station con remoterig e un TS480.
La connessione CatBkt-Radio avviene via seriale di remoterig.
Quando faccio la connessione, Catbkt si connette, sulla radio appare la scritta PC che sta ad indicare una connessione CAT in atto ma la frequenza non si aggiorna, nemmeno se premo più volte sincronizza. Per avere la sincronizzazione della frequenza devo riavviare catBkt diverse volte fino a che non si sincronizza e poi rimane sincronizzato fino a che non chiudo il programma. La cosa si verifica anche in locale, sia con Ts2000 che con Ts480 (senza remoterig di mezzo), con la differenza che al secondo riavvio del programma la sincronizzazione avviene.
C'è qualche parametro nel file.ini che posso provare a variare?
73 Maurizio
  Need key for IC-7100BKT
Posted by: VA7CV - 12-08-2016, 01:50 AM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (1)
Hi
Have not received key for IC-7100BKT
Glen
VA7CV
<!-- e --><a href="mailto:va7cv@rac.ca">va7cv@rac.ca</a><!-- e -->
  Apple Parallels Desktop
Posted by: iz2bkt - 12-03-2016, 05:57 PM - Forum: BktTimeSync - Replies (3)
Ciao, Mauro.
I am running 1.7.0 BktTimeSync and have started to have a problem with it (when having my computer awake from sleep).
1/27/16 22:32:49 --> Sync start P1
11/27/16 22:32:49 --> Sync NTP P1
11/27/16 22:32:49 --> 11/27/16 22:34:49Sync NTP OK, next to :
11/27/16 22:34:49 --> Sync start P1
11/27/16 22:34:49 --> Sync NTP P1
11/27/16 22:34:49 --> 11/27/16 22:36:49Sync NTP OK, next to :
11/27/16 22:36:49 --> Sync start P1
11/27/16 22:36:49 --> Sync NTP P1
11/28/16 00:23:37 --> Failed to retreive time from NTP server 132.163.4.102 on port 123, GetLastError returned 10060Sync NTP ERROR :
11/28/16 02:12:06 --> Sync start P1
11/28/16 02:12:06 --> Sync NTP P1
11/28/16 02:12:11 --> Failed to retreive time from NTP server 132.163.4.102 on port 123, GetLastError returned 10060Sync NTP ERROR :
11/28/16 04:00:47 --> Sync start P1
11/28/16 04:00:47 --> Sync NTP P1
11/28/16 04:00:48 --> 11/28/16 04:02:49Sync NTP OK, next to :
11/28/16 05:49:31 --> Sync start P1
11/28/16 05:49:31 --> Sync NTP P1
11/28/16 05:49:32 --> 11/28/16 05:51:49Sync NTP OK, next to :
11/28/16 07:38:11 --> Sync start P1
11/28/16 07:38:11 --> Sync NTP P1
I understand from <!-- m --><a class="postlink" href="http://www.maniaradio.it/forum/viewtopic.php?f=22&t=304&start=10">http://www.maniaradio.it/forum/viewtopi ... 4&start=10</a><!-- m --> that Error Code 10060 is a timeout error.
My problem is 100% repeatable, and occurs after waking my computer from sleep.
If I press the "Sync Now" button, BktTimeSync will detect and display the correct time, but if I do not, then the program will continue with the wrong time.
Strangely, if I wake the computer from sleep, and press "Sync Now" before the problem occurs, then BktTimeSync will go into the error state in a few minutes.
If I do not press "Sync Now" upon waking the computer, BktTimeSync will detect and display the correct time on the next cycle, but will go into the error state in a few minutes.
In other words, I have to wait until the error occurs to press "Sync Now".
My system is special, but it may give you some information about fixing the problem. I am running
Guest operating system - Win7/64 in emulation under Parallels Desktop 12
Host system - MacOS 10.12.1
Hardware - 2.6 GHz i7, 16 GB RAM
When I say 'sleep' above, I am referring to the MacOS (the host system) sleeping or waking. Win7/64 is open all the time.
My guess is that some memory variable is persisting in BktTimeSync, and causing the error upon reconnection. You would have far better knowledge.
I hope this helps you track down the problem in <!-- m --><a class="postlink" href="http://www.maniaradio.it/forum/viewtopic.php?f=22&t=304&start=10">http://www.maniaradio.it/forum/viewtopi ... 4&start=10</a><!-- m -->, and perhaps my problem.
73 Parker W5ADD
