  Activation code
Posted by: Donsass - 11-22-2017, 12:17 AM - Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori - Replies (3)
Hello, I am still awaiting my IC-706m2G activation code.
Thank you
  Windows "Set time automatically" setting?
Posted by: n1eu - 11-19-2017, 07:37 PM - Forum: BktTimeSync - Replies (4)
Should the Windows 10 setting 'Set time automatically" be turned on or off under "Date and time"?
  bktClock feature, add second display, Local & UTC
Posted by: n6yfm - 11-15-2017, 08:51 PM - Forum: BktTimeSync - Replies (1)
Hi:   I am a new user of BktTimeSync.
I really like the BktClock on screen feature and config options.
This is a new feature request for the bktclock function of bktTimeSync;
How hard would it be to add an additional clock display, and label
them "LOCAL" and "UTC" ?    I suspect a large number of the BktTimeSync
users might like that?
It could look like;
LOCAL   12:50:19
  UTC    20:50:19
Opinons/Comments?
Cheers,
Neal
N6YFM
  bktimesync locking up
Posted by: krutzy - 11-10-2017, 07:07 PM - Forum: BktTimeSync - Replies (18)
I posted this question:
https://www.maniaradio.it/forum/showthread.php?tid=356
That solve the problem.  The parameters are the same.  Now bktimesync locks up after initial synchronization.  I does the sync, but locks up.  I can close the program with the "X" and then I get the standard "problem with this program, searching microsoft for answers", or whatever that message is.  Any ideas?
eTrex H with usb com cable, Windows 7 Ultimate 64 bit.
Thank you!
Kevin
  offset
Posted by: OE3NFC - 11-06-2017, 09:30 AM - Forum: BktTimeSync - Replies (1)
Good morning, just installed version 1.9.1 and suddenly there is a difference between NTP and GPS of nearly 2sec.
Did not experience that with the previous version?
Many thanks - Norbert
  BktTimeSync Version 1.9.x
Posted by: iz2bkt - 10-29-2017, 09:49 AM - Forum: BktTimeSync - No Replies
Is available for download:
BktTimeSync Version 1.9.1:
- Added Sync Log
- More compatibily with Windows 10 Fall Creators Update
http://www.maniaradio.it
  CatBkt Version 1.12.x
Posted by: iz2bkt - 10-11-2017, 09:05 AM - Forum: News / Novità - No Replies
Is available for download IC7100BKT:
Version 1.12.0 : Support BktDxCluster
  IC706_BKT Version 4.19.x
Posted by: iz2bkt - 10-11-2017, 09:02 AM - Forum: News / Novità - No Replies
Is available for download IC706_BKT:
Version 4.19.0 : Support BktDxCluster
Version 4.19.1 : link update
Version 4.19.2 : Improved audio device management
Version 4.19.3 : Correct key loading for the trial version
  IC7000BKT Version 1.29.x
Posted by: iz2bkt - 10-11-2017, 08:58 AM - Forum: News / Novità - No Replies
Is available for download IC7000BKT:
Version 1.29.0 : Support BktDxCluster
Version 1.29.1 : lunk update
Version 1.29.2 : Improved audio device management
Version 1.29.3 : Correct key loading for the trial version
  IC7100BKT Version 1.11.x
Posted by: iz2bkt - 10-11-2017, 08:52 AM - Forum: News / Novità - No Replies
Version 1.11.0 :
Version 1.11.1 :
  • link update
Version 1.11.2 :
  • Fixed the step in the Scanner function
Version 1.11.3 :
  • Correct sort of grid in edit memories window
  • Added automatic power on of RTX in activation of a sked
Version 1.11.4:
  • Improved Filter management with mode change
Version 1.11.5:
  • Improved audio device management
Version 1.11.6:
  • Correct key loading for the trial version
