| High CPU Usage |
Posted by: krutzy - 09-29-2017, 07:13 PM - Forum: BktTimeSync
- Replies (7)
I have BktTimeSync 1.8.2 installed. I run on a Dell Latitude E6400, P8600 dual core, 8 GB ram, Win 7 Ultimate 64-Bit.
I use BktTimeSync for proper time calibration for use with WSJT-X. Where I operate, I do not have internet, so I synchronize via my a COM port to a Garmin ETrexH.
The time sync works just fine. However, bkttimesync uses a lot of CPU. If I close bkttimesync through in the interface, it closes, however the bkittimesync process keeps running and I have to terminate the program via Task Manager.
Anyone else have this issue or know what I can do to not have the program use so much CPU?
Thank You.
Kevin
| Working but... |
Posted by: W8NEE - 09-01-2017, 01:30 AM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori
- No Replies
I got the program up and running using Com 5. Tried to send CW into a dummy load and it worked and then quit and got loud signals from the laptop and system quit. I'm missing something, can't figure it out. I did start it back up, seemed o.k. but didn't attempt sending again. Rig is an IC7100
| GPS QRP-LAB no run |
Posted by: EA4GHB - 05-22-2017, 06:18 PM - Forum: BktTimeSync
- Replies (5)
Hi all.
I try to use Bkt timeSync with a qrp-lab gps. it´s a YIC5. but no run.
The program work good with a Ntp server, but not in gps mode.
My OS is win 8.1 and gps is conected to PC like this:
1PPS--------------pin 1 of DB9
TxD--------------- pin 2
RxD---------------pin 3
Win recognice the device, and assing a COM. but Bkt TS no run.
what i´m doing wrong?
Thanks for help.
73!
Alberto-EA4GHB
| IC7100BKT Version 1.9.x |
Posted by: iz2bkt - 04-30-2017, 03:50 PM - Forum: News / Novità
- No Replies
Available for download IC7100BKT Version 1.9.0:
Added 1KHz note for software tuning
Added the option to send by enabling USB input during 1KHz software tuning or 1750Hz note output
| Access data |
Posted by: WM1KE - 02-27-2017, 02:37 AM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori
- Replies (4)
Mauro, et al:
I am a registered BKT owner. works nice.
I am doing propagation research and would like to access the rigs S-meter. Other fata would be nice but I will be happy with S-meter.
I know that other DDE based apps can access the data but I can not find a way to
build DDE into my code.
Is there any way to access data like S-meter, SQL level, etc?
My fallback is to software Tee the COM port and examine the CIV myself (yuck).
73, Mike
