  Audio Windows Warning/Failure
Posted by: herbpk - 04-09-2018, 01:54 AM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (1)
Just downloaded the latest IC 70000BKT - 1.29.0
I have a new issue I have been seeing:
Error 4 from the audio device
It has been appearing irregular and never saw this on many years of previous versions and updates.
I don't actually see any issues on CAT control.
Any thoughts?
73'
n2gew
Attached Files Thumbnail(s)
  BKT Time Sync don't start with Win 7 [SOLVED]
Posted by: F6DFZ - 03-22-2018, 05:05 PM - Forum: BktTimeSync - Replies (4)
Dear Mauro,
I am using your fine software, version 1.9.1 for a few years, with Win 7, without any issue.
But since a few months, BKT TS doesn't star at Win 7 startup.
I tried to install/uninstall, and even asked Win 7 to start it automatically, but without any success.
A friend of mine, F6AFU, has the same setup and the same problem.
I contacted my friend Rémy F6ABJ, but it couldn't help.
Here is a screen copy of my parameters.
So Mauro I would appreciate your help.
Thanks and best regards
Georges F6DFZ
  Program registration
Posted by: ok1vvt - 02-09-2018, 08:25 AM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (3)
Thank you for a great program, I received the activation key file and when I am trying to register program i get a notice
Error 6 in the load the key
Is there any way how to fix it ?
73! and best regards
Vasek OK1VVT
  BktTimeSync Phone 1.0.0
Posted by: iz2bkt - 01-08-2018, 05:18 PM - Forum: BktTimeSync - No Replies
A new way to synchronize your PC clock using the GPS receiver of your Android smartphone.
BktTimeSyncPhone Version 1.0.0 download from http://www.maniaradio.it/en/bkttimesyncphone.html
  GPS device supported?
Posted by: n1eu - 12-04-2017, 01:18 AM - Forum: BktTimeSync - Replies (1)
Will this GPS device work with BktTimeSync?  https://www.ebay.com/itm/VK172-G-MOUSE-U...SwzaJX-0hX
  Compilazione su raspberry
Posted by: iz5rng - 12-03-2017, 09:30 AM - Forum: General discussion - Problems - Bugs / Discussioni - Problemi - Errori - Replies (3)
Ciao a tutti,
espongo il mio quesito.
Ho una stazione remota (distante una ventina di km da casa) che vorrei controllare e usare da casa.
Vorrei utilizzare un raspberry con le librerie hamlib e mumble e vedo che il software catbkt fa proprio questo, sebbene in locale.
La scelta del raspberry cade essenzialmente sul basso costo, il basso consumo, la possibilità di essere gestito completamente da remoto e non ultimo i bassi consumi.
Vorrei se possibile qualche informazione in più sul software catbkt.
Sarebbe possibile "modificarlo" per dialogare con una hamlib remota anzichè locale?
Grazie delle info.
Massimo
IZ5RNG
  Unable to connect to COM Port greater than COM20
Posted by: n1eu - 11-24-2017, 07:09 PM - Forum: BktTimeSync - Replies (3)
Whenever I remove and re-pair my bluetooth GPS receiver, Windows 10 assigns a new COM port pair and increments the port number.  I am now at COM24 for the output port and BktTimeSync seems unable to list available COM ports over COM20.  Can you possibly add support for higher COM port numbers?
Thanks & 73,
Barry N1EU
  PTT keying
Posted by: Donsass - 11-24-2017, 05:07 AM - Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori - Replies (1)
I have the 706MK2G software installed and mainly working under windows 7. Unfortunately the PTT key function does not seem to work. My configuration is:  COM1, 9600,8,1,N,RTS and DTS = OFF   PTT is enabled on COM1 :RTS  PTT key is CTRL.  The Tune function works but neither pressing the CTRL nor clicking on the mic icon (although the red light glows on) seems to work. I have changed  PTT and COM1 configurations using DTR, serial port modes and different com speeds but nothing works.
Do you have any suggestions.
Thank you
  BktTimeSync Failed to Start
Posted by: Rick - 11-22-2017, 06:45 PM - Forum: BktTimeSync - Replies (1)
The last couple of mornings BtkTimeSync has failed to start at Windows bootup?
     OS Windows 7 Pro 64
     BktTimeSync Version 1.9.1
     Time from an enabled GPS
     Sync Every 5 minutes
     Error Msg:
         Last Sync :Wednesday, November 22, 2017 07:37:01
         Failed to set the local time
After more than 30 minutes it had still not tried to resync. I  stopping BktTimeSync in Task Manager (it was taking 25% CPU) and restarted it. Since the restart it has run correctly.
Since this is a new program for me I have been monitoring BktTimeSync on the task bar. When I hovered over the icon I saw the error message?
I'm curious if anyone else has seen this?
Rick
VE7TK
  Normal Thread
Posted by: UR5WCE - 11-22-2017, 01:36 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (1)
Hi!
The work of the IC7100BKT program is available Orbitron program?
