  Ver 1.12.1 starts then unresponsive - SOLVED
Posted by: KA1LM - 09-12-2023, 01:44 PM - Forum: BktTimeSync - Replies (2)
I installed version 1.12.0 with Administrator rights on my Win10 laptop. GPS is connected and has drivers. The setup page starts, displays GPS lat/lon, altitude, time, grid square, instantly; then turns gray. I can not change anything from defaults and the screen says "Not responding". After several popups, status shows laptop clock was synched. Windows Task Manager shows BktTimeSync "Not responding".
I left it running last night, this morning, the taskbar hidden apps showed the icon, but it disappeared after a minute.
I uninstalled ver 1.12.0 and installed 1.12.1; again with administrator rights, same results.
Huh
ANY ideas?
Duane
  Mumble rumore di fondo
Posted by: scandio - 09-07-2023, 01:41 PM - Forum: BktRemote Suite - Replies (1)
in questi mesi ho usato intensamente la gestione remota per l'IC706: costantemente nell'audio (in entrambe le direzioni)
si sente un fastidioso rumore di fondo (assomiglia ad un gorgoglio di acqua): come è possibile ridurlo ?
cordiali 73
I2WQ Scandio
  Ho to localize IC7300BKT
Posted by: iz2bkt - 08-30-2023, 05:59 AM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - No Replies
How to localize the program:
1. Go to the installation folder ( Ex. C:\IZ2BKT\IC7300BKT Icom CAT Control )
2. Copy the file english.lng to the Documents folder
3. Rename the file english.lng with the name of the translated language (ex. spanish.lng)
3. Run BKTLocalize
4. Select the file created in step 3
5. In the cells of the right column, write the translation or leave the cell empty to not translate the sentence
6. Once the translation is complete, click on [Save and Close]
7. Copy the translated file to the installation folder of IC7300BKT
8. Launch IC7300BKT and in Utility->Configuration click on [Change Language] to select the new language
IMPORTANT:
Do not replace the special characters % and \
The translated sentence must not be longer than the original one
If you want, you can send me the translated LNG file, and I will place it in the program's installation.
  How to localize BktTimeSync
Posted by: iz2bkt - 08-30-2023, 05:46 AM - Forum: BktTimeSync - No Replies
1. Go to the installation folder ( Ex. C:\Program Files (x86)\BktTimeSync )
3. Run BKTLocalize. From BktTimeSync version 1.20.0 onwards, use BktLocalize_Unicode.
7. Copy the translated file to the installation folder of BktTimeSync
8. Launch BktTimeSync and click on [Change Language] to select the new language
IMPORTANT:
  Language
Posted by: EA3W - 08-29-2023, 09:10 AM - Forum: BktTimeSync - Replies (6)
Hello everybody:
I am Xavi EA3W, I have done translations of many programs (JTDX, WSJT-X, TQSL) and I offer to do the translation into Spanish and Catalan of this software and of whatever you think is necessary.
greetings 73
  ic7000 remote e server
Posted by: Massimo - 07-24-2023, 08:50 AM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (3)
ciao a tutti.forse cualcuno mi puo auitare,volevo metere la radio ic7000 a remoto che la posso usare via internet,ma con il audio non ce la faccio.la mia configurazione audio ho provato come nel istruzioni.ma non va,poi ho provato con il acc della radio pin 11 e il pin 12 neanche va adesso no so piu cosa fare forse mi puo aiutare cualcuno step per step. grazie e 73 de massi hb9dnx
scusate il mio italiano
  Interfaccia ic7300 BBLogger
Posted by: IZ4EKI - 07-12-2023, 06:27 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (7)
Buona sera a tutti. Sono IZ4EKI Tomaso
Ho appena collegato al pc il mio ICOM IC730 , avrei piacere interfacciarlo con Bbloger per il CAT da usare per tutti i modi di trasmissione e usufruire delle altre potenzialità' del programma.
Istallato driver del 7300 nel PC
Collegati IC7300 col cavo USB.
Riconosciuto dal PC.
Ora vi chiedo come debbo continuare per arrivare al traguardo?
Vi ringrazio.
Saluto 73 de IZ4EKI Tomaso
  Accedere a BBLogger
Posted by: it9hlr - 07-05-2023, 10:43 AM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (1)
desidero sapere se è possibile all'apertura del programma in oggetto, trovare IC7000BKT con la pagina già minimizzata così da evitare tutte le volte di farlo manualmente. Grazie.
Salvo, it9hlr
  Run for all Users
Posted by: NN4RB - 07-03-2023, 08:42 PM - Forum: BktTimeSync - Replies (3)
Is there a way to run BktTimeSync for all PC users?
Any help would be appreciated.
Rick
  Autogrid setup for udp multicast
Posted by: AB8WD - 05-24-2023, 01:39 PM - Forum: BktTimeSync - Replies (1)
I am running multicast on WSJt  124.0.0.1  2237 works with all others
I am being messaged that my grid is not showing up in wsjt
I tried to set the autogrid in bktimesync and it shows 2.237 and 2240001 and will not let me edit or fix any ideas
also seems timesync is not syncing to wsjt anymore still working on that thanks in advance
de ab8wd
