| lost clock display (SOLVED) |
Posted by: wa4yiz - 05-15-2023, 05:08 AM - Forum: BktTimeSync
- Replies (2)
hi all...been using gps bkt time sync for a while....changed the monitors on my pc..now the "clock" in time sync does not display..any ideas ?? thanks jim wa4yiz
| BktTimeSync Version 1.12.x |
Posted by: iz2bkt - 04-10-2023, 09:16 AM - Forum: BktTimeSync
- No Replies
Is available for download:
BktTimeSync Version 1.12.0:
- Adding support for WSJT-X AutoGrid
BktTimeSync Version 1.12.1
- Added translations in Catalan and Spanish (thanks to Xavi EA3W).
- Uninstalling the program also resets the main display and startup parameters.
BktTimeSync Version 1.12.2
- Added help and manual in Catalan and Spanish (thanks to Xavi EA3W).
- Improved unistall
| how to save TONE setting in memory editor? |
Posted by: VK2AAF - 03-10-2023, 09:23 AM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori
- Replies (1)
I am trying to save the transmit CTCSS TONE selection in a memory.
I set TONE in Tx Ac T. I press ENTER. Then I click SAVE. TONE disappears. So that doesn't work.
I set TONE in Tx Ac T. I press ENTER. Then click SAVE and Active. TONE disappears. That doesn't work.
How do I save TONE 'on' in a memory?
This is not addressed in the Editing Memory Bank area in the HELP file.
In case it matters, I can use the live control panel to turn TONE on and off. That works.
Help?
Thanks
73 de Brian VK2AAF
| registration not working SOLVED |
Posted by: VK2AAF - 02-22-2023, 12:43 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori
- Replies (5)
Hi Mauro
I received the key zip file
unzipped it in the C:\IZ2BKT\IC7000BKT Icom CAT Control folder
ran IC7000.bkt
found 'register program,' pointed it to VK2AAF.ic7000bkt.bkt
program responded that registration would work after program is restarted
restarted program
program knows my callsign but registered functions don't work, asks to register again
repeat repeat repeat
help please
thanks
| Can't make settings anu more |
Posted by: pc2c - 02-19-2023, 04:18 PM - Forum: BktTimeSync
- Replies (1)
I have installed the latest version of BktTimeSync on Windows11. The first time I started up I got a setup screen where I could set some things.
I'll determine when and how to synchronize the time and everything seemed to be working properly.
The second time I launched the program, nothing visually happened, not a single screen popped up. So I can't set or change anything anymore.
There is nothing in the taskbar either. The time is synchronized (every hour) correctly so the program is running. I can see this in the Windows notifications.
Un-installing and re-installing won't help.
What am I doing wrong?
Thanks in advance.
Rene
| ic-706 on/off |
Posted by: sv8alq - 02-10-2023, 05:16 PM - Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori
- Replies (2)
Good evening. I just registered to this program for ic-706. I like some times to work remote from another pc on the same network. The software is connected to ic-706. What i need to do is to connect to remote pc to run the software and put on or off the radio but i cannot see any button in software.
Is anybody here tried to do this?
thank you.
| Nat Provider |
Posted by: icom64 - 12-22-2022, 03:31 PM - Forum: BktRemote Suite
- Replies (1)
Volevo utilizzare il programma BktSuite per collegare la mia stazione che si trova a casa dei miei genitori, dove non c'e' l'adsl, utilizzando una connessione mobile con sim e router. C'e la possibilità di aprire le porta utilizzate dal programma con questo tipo di connessione? Avendo fatto delle prove in merito (tramite es desktop remoto) abbiamo constatato che le porte sono nattate.
saluti '73 IK3ZBG
