| Grid update interval for WSJT-X |
Posted by: N1JEZ - 04-14-2024, 04:55 PM - Forum: BktTimeSync
- Replies (1)
Would it be possible in a future revision to add a select able update interval that is separate from Time Sync? As it stands now, grid updates only get sent when a time sync is sent.
If I'm operating portable in motion, it would help to have the grid updated at a more frequent interval than my usual 1 hour for Time sync.
Tnx, Mike
| Localize Japanese |
Posted by: Toshiyuki Onaka - 03-02-2024, 08:51 AM - Forum: BktTimeSync
- Replies (1)
Mauro san
I created Japanese.lng which is translated into Japanese.
How can I have it included in the next release?
If you would like to send it by email, please let me know your email address.
| Info File Hamlib per Yaesu FT-710 |
Posted by: Fabrizio Meli - 03-01-2024, 04:22 PM - Forum: Yaesu
- Replies (4)
Come nuovo iscritto porgo un cordiale saluto a tutti.
Le mie condizioni di utilizzo sono BBLogger + CatBkt con Yaesu FT-710.
Premetto che questo set funziona perfettamente, pur tuttavia mi pongo un problema probabilmente futile ma comunque credo interessante.
Per accoppiare l' FT-710 con CatBkt devo utilizzare l'impostazione dell' FTdx10 che praticamente ha la stessa logica di comunicazione.
Ho visto con altra applicazione che Hamlib ha rilasciato il file dedicato e stabile per il FT-710.
Chiedo pertanto gentilmente se fosse possibile aggiornarlo anche in CatBkt.
Grazie e 73 de I0FZM
| IC-746Pro |
Posted by: wa1rkt - 02-22-2024, 04:27 PM - Forum: Icom
- Replies (3)
So, do I understand correctly that there is nothing similar to IC706_BKT for the Icom IC-746Pro?
Any plans for that any time soon?
If not, can anyone suggest an alternative program from somewhere else that will program the IC-746Pro?
Thanks...
Rick WA1RKT
Londonderry, NH, USA
Catch me on 14.300 MHz Intercon / MMSN most days
| IC706_BKT configuration page, and getting started |
Posted by: wa1rkt - 02-15-2024, 08:38 PM - Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori
- Replies (4)
Good afternoon from snowy New Hampshire, USA.
Just getting started with IC706_BKT and so far have not been able to get it to work.
I need an Icom CT-17 or equivalent cable, right? I have the LCU3-I and OPC-478 cables and they don't work, so I assume I need to get a CT-17 equivalent cable, right?
Second question... how do I get back to the IC-706_BKT configuration page? When I first started it up it took me to the config page but since then it just takes me to the main page and I can't change the configuration. I assume there is something I click to take me to the configuration but I don't see it.
The defaults are 19200-8-N-1, RTS and DTR both ON. Is that the correct configuration to talk to the IC-706MKIIG?
Thanks...
Rick WA1RKT
| Scheduled Task Missing from 1.13.1? |
Posted by: khisel - 02-05-2024, 03:33 AM - Forum: BktTimeSync
- Replies (1)
Maybe I messed something up, but I installed 1.13.1 and it would not auto start with Windows. I found a reference to the Scheduled Task here on the forum that launches the program (with privilege to avoid UAC) and noticed I did not have this task. I found the .xml task and imported it, but Windows indicated that it was malformed. I uninstalled everything and found my copy of 1.12.2 and it properly installed the task and worked as expected (after the 2-minute delay). I then updated to 1.13.1 and everything is working properly.
It's possible that my copy of the 1.13.1 installation file is bad, but that seems unlikely. Just thought I would mention this.
Thanks for an excellent program—I use the GPS on my main server in my home and my other machines NTP into it.
