| COM Configuration |
Posted by: iz2bkt - 11-07-2010, 01:24 PM - Forum: General discussion - Problems - Bugs / Discussioni - Problemi - Errori
- Replies (2)
Comm parameters of some popular radios:
Manufacturer Model Rate Data bits Stop bits Parity
Alinco DX-77 9600 S 2 N
Elecraft K2 4800 8 2 N
Elecraft K3 4800 8 2 N
ICOM IC-706 19200 8 1 N
ICOM IC-718 19200 8 1 N
ICOM IC-725 9600 8 1 N
ICOM IC-735 9600 8 1 N
ICOM IC-746 19200 8 1 N
ICOM IC-751 9600 8 1 N
ICOM IC-756 19200 8 1 N
ICOM IC-761 9600 8 1 N
ICOM IC-765 9600 8 1 N
ICOM IC-775 19200 8 1 N
ICOM IC-7000 19200 8 1 N
ICOM IC-7800 19200 8 1 N
Kenwood TS-140 9600 8 2 N
Kenwood TS-440 4800 8 2 N
Kenwood TS-450 4800 8 2 N
Kenwood TS-570 57600 8 1 N
Kenwood TS-690 4800 8 2 N
Kenwood TS-790 4800 8 2 N
Kenwood TS-850 4800 8 2 N
Kenwood TS-870 57600 8 1 N
Kenwood TS-930 57600 8 1 N
Kenwood TS-940 4800 8 2 N
Kenwood TS-950 4800 8 2 N
Kenwood TS-2000 57600 8 2" N
Te n-Tee Argonaut 1200 8 1 N
Te n-Tee Jupiter 57600 8 1 N
Te n-Tee Omni VII 57600 8 1 N
Te n-Tee Orion 57600 8 1 N
Te n-Tee Pegasus 57600 8 1 N
Yaesu FT-100 4800 8 2 N
Yaesu FT-450 38400 8 1 N
Yaesu FT-736 4800 8 2 N
Yaesu FT-747 4800 8 2 N
Yaesu FT-757GX 4800 8 2 N
Yaesu FT-767GX 4800 8 2 N
Yaesu FT-817 38400 8 2 N
Yaesu FT-840 4800 8 2 N
Yaesu FT-847 57600 8 2 N
Yaesu FT-857 38400 8 2 N
Yaesu FT-890 4800 8 2 N
Yaesu FT-897 38400 8 2 N
Yaesu FT-900 4800 8 2 N
Yaesu FT-920 4800 8 2 N
Yaesu FT-950 38400 8 1 N
Yaesu FT-1000D 4800 8 2 N
Yaesu FT-1000MP 4800 8 2 N
Yaesu FT-2000 38400 8 1 N
Yaesu FTDX-9000 38400 8 1 N
| IC706_BKT Version 4.5.x |
Posted by: iz2bkt - 10-25-2010, 06:09 AM - Forum: News / Novità
- Replies (4)
New features planned in the next version 4.5.0 :
-Font selection for the main form and secondary windows (memory, PTT, AudioRecorder)
Also you can change the font size to increase or to shrink the main window.
| BKTServer |
Posted by: VK6YNE - 10-21-2010, 09:36 AM - Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori
- Replies (4)
I have a question on remote operation using BKTServer. The program works as it should locally but if i try to operate using BKTServer I get a Com0 error remotely. I can receive the audio from the server but cannot operate the radio.
I went back to the BKTserver and found that the notes box says error0 each time I press start. Originally when I installed it gave me an ip address for the client but now it does not just the error message.
I have not had it work remotely so far. I have check that the firewall is not interfering and that the port 7060 is available.
Can you offer any assistance?
Regards,
Nick VK6YNE
p.s A great program so far but I would like to be able to operate remotely from my radio. Thanks in advance
| ERROR WHILE TRYING TO PROGRAM MEMORY BANK |
Posted by: K2OMN - 10-09-2010, 02:12 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori
- Replies (1)
Greetings,
I guess the primary problem is when I try to either read in the band limits it does so incorrectly. I try to input the band limits manually and it saves them ok.
However, when I try to save a memory I'm manually entering it give me an error "The RX and TX are out of limits..."
I even ensured that the band limits were set correctly on the drop down menu.
Although I can still save my data and upload it to the IC-7000 the error message is an issue.
Any thoughts about this error message and how I can resolve it?
I really like this software pacakge, its quite functional and elegant in design although I can't figure out how to manually change frequency channels using the panel.
Thanks and 73,
Joe
| FT-DX5000MP |
Posted by: iz0pue - 10-06-2010, 01:26 PM - Forum: Yaesu
- Replies (1)
Sono uno dei primo (il primo a Roma) possessori di questo nuovo apparato di yaesu
Veramente magnifico, ma come tutti gli apparati nuovi di pacca i problemi si risolvono passo passo...
allora premessa: IL SOFTWARE iz2bkt funziona perfettamente, basta settare per bene sia il sftw che l'apparato.
PRIMO: NON FATE L'AGGIORNAMENTO DEL FIRMWARE CON QUELLO PRESENTE SUL SITO YAESU.COM (SIGLATO 0526)
QUESTO FIRMWARE E' PER LE VERSIONI USA E IN QUELLE EUROPEE MANDA IN CRISI UN PO TUTTO TRA CUI IL CAT
fatto questo (o meglio... non fatto) siete a meta' dell'opera, adesso basta configurare i menu cat della radio in questo modo:
032 GENE - CAT BPS - 38400BPS
033 GENE - CAT TOT - 3000MS
034 GENE - CAT RTS - DISABLED
035 GENE - CAT IND - ENABLED
invece nel software dovete settare con radio FT-2000 e la vostra porta COM
lasciate spuntato il flag che dice di usare i parametri di defaulth per quella radio
Adesso tutto filera' liscio.
se avete bisogno di aiuto scrivetemi pure.
PS: MI RIPETO: NON FATE L'AGGIORNAMENTO DEL FIRMWARE
| mini bkt docking station |
Posted by: hitechmisfit - 10-03-2010, 04:30 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori
- Replies (2)
I just turned on my winamp ( using the modern skin ) that has a docking station the slides up out of the way when not in use. I was think this idea would be great for the bkt software. Frequency read out, Memory read out, vol, sql. mute, scan start stop buttons. Then when maximized it would revert back to the bkt screen we are familiar with now. Please go look at the winamp bar and see what you think of the idea. It is skin - modern. Thanks for your time, Mike
| IC7000BKT Version 1.10.x |
Posted by: iz2bkt - 10-03-2010, 12:53 PM - Forum: News / Novità
- Replies (3)
New features planned for the next version IC7000BKT 1.10.0 :
- Delete Block: clear memories from n# to n#
- Remap : remaps the memories with sorting chosen
- Save As : save memories in a file
- Load From : load memories from a file
This version will be available after 15 October 2010.
| Memory sorting |
Posted by: g0ifi - 10-02-2010, 12:08 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori
- Replies (7)
IC7000BKT is the best control program out there for the 7000, there is just one feature I would like: in memory management, it would be very useful to be able to sort memories by name or frequency.
For example, you might have memory number 1: 144.525, memory number 2: 10.140, memory number 3: 7.100 and so on, but you want the memory numbers to ascend in frequency so that memory 1 is 7.100, 2 is 10.140 and 3 is 144.525 and so on. If you have hundreds of frequencies in memories it can take a long to time rearrange them. Something that does this job at the click of a button would be handy.
Thanks for a great program!
73 Perry G0IFI
