| Connect using VSPE Virtual Serial Ports Emulator |
Posted by: iz2bkt - 04-25-2011, 09:11 AM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori
- No Replies
If you can't connect to the rtx with the program could be a drivers problem, especially if you use USB interfaces, to resolve this problem, you can try to use a virtual COM port:
1) Download the Virtual Serial Ports Emulator VSPE ( free for 32 bit operating systems ) from here: http://eterlogic.com/Products.VSPE.html
2) Install and run VSPE
3) Power On the RTX
From VSPE:
4) From the Menu Device select Create
5) In Device Type select Splitter and click Next
6) In Virtual Serial Port select a COM free (or leaves that proposal from the program)
7) From Date Source Serial Port select the COM connected to rtx
8) Un-check Read-only and Redirect modem registers
9) Click End
From IC7000BKT:
10) Launch the program IC7000BKT ( version 1.15.0 or higher )
11) Go to Utility->Configuration->Com configuration
12) In Port select the COM created in point 6
13) In Serial Port Mode select MODE 2
14) Confirm all with OK
| IC7000BKT Version 1.15.x |
Posted by: iz2bkt - 04-23-2011, 08:51 PM - Forum: News / Novità
- Replies (2)
IC7000BKT Version 1.15.0 :
- Out the support for Windows 2000.
- In the configuration COM is also possible to choose the COM not connected to any device.
- Improved the saving and restoring the windows position.
- Added registration and Auto Power Off in Skeds.
| IC706_BKT Version 4.7.x |
Posted by: iz2bkt - 03-26-2011, 10:31 AM - Forum: News / Novità
- Replies (2)
IC706_BKT Version 4.7.0 :
- Added the Polling mode.
- Corrected minor problems ( rescue position windows, size fields, correction window closure request registration ).
- Improved calculation of connection speed.
- Improved the program startup.
| IC7000BKT Version 1.14.x |
Posted by: iz2bkt - 03-24-2011, 09:17 PM - Forum: News / Novità
- Replies (2)
IC7000BKT Version 1.14.0 :
- Fixed a bug that resets the file memories when run certain plug-in on startup.
| PSE INFO CATBKT |
Posted by: ik0vtg - 03-22-2011, 01:57 PM - Forum: General discussion - Problems - Bugs / Discussioni - Problemi - Errori
- Replies (3)
ciao a tutto il forum , complimenti per il programma.
Ho cercato di uare il tuo prg con IC 756 pro 3 e le porte splittate di VSPE per usare
piu' prg insieme ,( questo lo faccio normalmente con tutti i prg in
digitale) purtroppo non le legge VEDE SOLTANTO LE COM ( USB )ISTALLATE.
Cortesemente c'e' qualche modo per poterlo fare? o debbo settarle
diversamente?
ringrazio anticipatamente per le informazioni.
Ciao 73 de Giancarlo IK0VTG
| Blocco programma |
Posted by: it9hlr - 03-14-2011, 08:01 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori
- Replies (2)
grazie per la nuova chiave.
Sto avendo problemi con il programma, dopo pochi minuti che funziona si
blocca tutto.
Ho variato la porta,la velocità non so cos'altro fare.
Uso un cavetto usb nuovo,mi è arrivato proprio oggi.
Ho provato sia sulla radio che nel programma a variare la velocità, ma si
blocca!
Il blocco avviene dopo che con la radio mi sono spostato di freq.,cambiato
banda ecc.
Se lascio tutto fermo non si blocca.
Cosa mi suggerisci di fare?
