  Installation and Configuration
Posted by: HB9DHY - 02-04-2013, 02:36 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (4)
Unable to configure and get running. Program hangs.
Configuration details:
Dell XPS M1330 ; Intel Duo CPU ; T8300@2.4GHz; RAM 4 GB ; Windows 7; 32 Bit; SP1;
Interface: RigTalk RT1-USB version of the Icom CT-17 Serial Interface; COM 5; Setting 19.2, 8N1N; Driver WMR, 21.07.2010, version 6.1.0.0;
PROBLEM: IC7000BKT version 1.19.1; Run ic7000bkt_Setup.exe; Run IC7000BKT Icom CAT Control; Program Hangs, 8 bars in ’Initialization in process’ window; Status 5038; allow program another few minutes to initialize; can only close with ‘Task Manager’;
RETRY: check port config, then RUN ic7000bkt_Setup.exe; Hangs the same; Status2037………….. Tried several times and get Status of 6293, 2060, 4025, ………………
De-Install 1.19.1; clear C: of IZ2BKT folder and its IC7000BKT Icom CAT Control; Re-Start PC Folder; Install version 1.14.2; Failure the same; Status 5039; ………………………
RETRY: check port config, then RUN ic7000bkt_Setup.exe; Hangs the same; Status2037………….. Tried several times and get Status of 6293, 2060, ………………
De-Install 1.14.2; clear C: of IZ2BKT and its IC7000BKT Icom CAT Control; Re-Start PC; Install version 1.19.1; Failure the same; ………………………
Other programs, Commander v 5.8.7 seem to function correctly. I am not aware of and appropriate reference program.
Thanks for the assistance, Mike, HB9DHY
  registration
Posted by: Glennp - 01-28-2013, 04:33 PM - Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori - Replies (6)
I am having problem registering my program. The instruction state select the folder. What folder what is the folders name and were lo located. I do not understand saved to the point 1. what is point one. Any help explain this to me. Thanks
  TS 850 S
Posted by: iz1wix - 01-24-2013, 09:49 AM - Forum: Keenwood - Replies (3)
Buongiorno , ho scaricato l'ultima realise , ma purtroppo non funziona bene, si blocca spesso , l' smeter non funziona , i filtri non sono attivabili.
Attendo ulteriori miglioramenti .
Grazie e complimenti per il software free.
  Mark V Field & CATBKT
Posted by: IW4DQY - 01-19-2013, 08:43 AM - Forum: Yaesu - Replies (10)
Vorrei riuscire a far funzionare questa accoppiata ma non ci riesco , anche con la nuova versione di CATBKT appena uscita.
Uso VSPE per splittare la com3 sulla com6 che uso con Easylog , HRD , Mpfilter e tutto funziona correttamente.
Quando avvio CATBKT la frequenza sintonizzata sulla radio comincia a saltellare su valori completamente astrusi , la radio commuta qua e la , CATBKT segna valori di frequenza con numeri
casuali .
Questa è la mia esperienza . Anche bypassando VSPE e facendo lavorare CATBKT sulla com3 rerale ho i medesimi effetti.
C'è qualche soluzione ?
Attendo fiducioso.
Grazie e cordiali '73
Giuseppe iw4dqy
<!-- e --><a href="mailto:iw4dqy@teletu.it">iw4dqy@teletu.it</a><!-- e -->
  ft950 e CAT - RISOLTO
Posted by: it9agz - 01-17-2013, 07:31 PM - Forum: Yaesu - Replies (7)
Ciao
innanzi tutto complimenti per lo sforzo ed il tempo che ci dedichi e per l'ottimo prodotto che hai creato.
Sono un affezionato utilizzatore di BBloger e da poco mi sono dedicato ai modi digitali, vorrei utilizzare il tuo programma per interfacciare la radio, ho seguito i vari suggerimenti dei colleghi che si sono succeduti ma purtroppo non ci riesco, sicuramente per miei errori (non sono proprio bravo nell'uso del PC).
Innanzitutto la mia configurazione: RTX Yaesu ft950, interfaccia CG Antenna SB-2000, PC con Window XP 32 bit, ho scaricato le librerie 1) hamlib-1.2.15.3.tar, 2) hamlib-win32-1.2.15.3.
Ho provato, come hai suggerito, di utilizzare come RTX dummy 1 e va bene.
Le mie domande:
1) quale delle 2 librerie hamlib utilizzo?
2) come utilizzare quella giusta, cioè dove andarla a posizionare? in quale cartella ecc.
3) per utilizzare con Bbloger devo installare il programma dentro la cartella Bbcat o non è necessario?.
Saranno domande stupide e magari scontate, ma come ti ripeto non sono una cima nell'utilizzo del PC.
Grazie anche per la comprensione
Ignazio
  CatBkt - Version 1.2.0 - IMPORTANT
Posted by: iz2bkt - 01-16-2013, 08:47 PM - Forum: News / Novità - Replies (1)
Improved communication with the RTX.
Download from: http://www.iz2bkt.com/CatBkten_download.html
  Find the COM port bound to a USB GPS
Posted by: iz2bkt - 01-16-2013, 04:53 PM - Forum: BktTimeSync - Replies (1)
USB GPS receivers are associated with a virtual COM port to find this port proceed in this way:
Windows 7:
1 - Click the "Start" button on the desktop, then type "Device Manager" in the search box.
2 - Click the "Device Manager" link the in search results to open the Device Manager window.
3 - Scroll through the list of devices until you find the "Port (COM and LPT)".
4 - Click on the + to expand and see all the COM and LPT ports installed in the PC.
Windows XP:
1 - Click Start, click Control Panel, click Performance and Maintenance, and then click System.
2 - On the Hardware tab, click Device Manager.
  FT-950 CatBkt si blocca in sincronizzazione - RISOLTO
Posted by: iw8rao - 01-11-2013, 06:03 AM - Forum: Yaesu - Replies (7)
Primo post su questo forum.. un saluto a tutti.
Premetto che ringrazio di cuore l'autore di questo e di tutti i software che vengono prodotti GRATIS per tutti noi, vengo ad esporre il mio grosso problema.
Ho installato CatBkt su una macchina con Windows 7 64bit (nuova installazione) ma, dopo aver settato il programma, in fase di sincronizzazione compare la scritta "il programma non risponde" e per chiderlo devo intervenire agendo sui tasti CTRL-ALT-CANC e chiderlo dalla Gestrione Attività.
La radio è collegata tramite cavo seriale direttamente alla COM1 (non USB) del PC. Avendo aggiunto altre due porte seriali ho provato anche su COM 3 e COM4 ma il risultato è lo stesso.
Ho installato una vecchia versione di HRD e con questo non ho nessun problema, viene vista immediatamente su qualsiasi porta la vada a collegare.
73 iw8rao Domenico
  BktTimeSync Version 1.3.0
Posted by: iz2bkt - 01-01-2013, 03:10 PM - Forum: BktTimeSync - Replies (1)
BktTimeSync Version 1.3.0 :
- Added the possibility to choose the second of start time synchronization.
- Improved monitor window.
- Increased the speed of the serial port up to 115,200 baud.
- Added the display of coordinates, altitude and WWLocator if used GPS.
- The icon in SystemTray displays the last action taken.
- Added display a notification when it synchronizes
- Improved Italian translation.
- Changed the web page displaying the NTP server.
  IC7000BKT Version 1.19.1
Posted by: iz2bkt - 12-31-2012, 11:02 AM - Forum: News / Novità - Replies (1)
IC7000BKT Version 1.19.1 :
- Correct display transmitting frequency selecting memory with DUP directly from tab Memories.
