  Kenwood TRC-80 no control of frequency.
Posted by: ZS4L - 05-31-2013, 07:11 AM - Forum: General discussion - Problems - Bugs / Discussioni - Problemi - Errori - Replies (2)
Smile Hi All,
I am trying to get my Kenwood TK-80 / TRC-80 to work with the CATBKT software.
I have made an interface using the MAX-232 and 74C04 chips and it is communicating well.
I can change almost anything on the rig from the PC-but NOT the frequency , and I don't see the 'S' meter. The Frequency also displays ' OFFLINE'.
I really want to make this work for an article in our local Ham Magazine, so any help would be appreciated, I think it is in the software--I can send a copy of the TRC-80 command set if that is needed to verify the software.
Sometrimes, If I try the TS-570s software on the TRC -80 , it will read the frequency, but only when synchronising.
There are MANY of these rigs in South Africa, they are very good but hard to control, so the CATBKT software is a great help if working properly.
Many Thanks, de William , ZS4L
  Running IC706_BKT
Posted by: SM0IES, Lennart - 05-20-2013, 02:38 PM - Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori - Replies (2)
Something is missing, I should be a way or a possibility to run the program without a radio connected.
I have my "rig" out in the contryplace, not at home and it's not possible to set up anything in the program, for later transfer into the "rig".
I really miss that, it's possible to do so on my program for my FT-897.
Above that I would like to know how I can "insert" a freq in the middle of the list, if possible?
/Lempa
  IC706_BKT Version 4.13.1
Posted by: iz2bkt - 05-16-2013, 07:54 PM - Forum: News / Novità - Replies (1)
IC706_BKT Version 4.13.1 :
- Fixed some bugs and improved the import of memories from CSV files.
  Loading RTX memories
Posted by: k8eod - 05-12-2013, 10:14 PM - Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori - Replies (4)
When synchronizing the radio from a csv file on a thumb drive the program seems to work properly right up to the end. At which time I receive the following error message.
"IC706_BKT control of the RTX IC706 has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available."
I have not found reference to this problem in the forum. Can you tell me what I need to do to correct the error?
Tried to attach my CSV file to this post but was rejected. I'll send separately.
Tom, K8EOD
  Microphone panel mod
Posted by: kc7ido - 04-20-2013, 07:40 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (2)
I was thinking it wouldn't be a bad idea to have a assignable keyboard button for use in the mic panel.
EX: With options to assign a key or keys from the keyboard to preform some functions like PTT, MUTE, Vol up/down, have the controls with on/off option on the mic panel.
Would be nice to lean back in the chair and "KEYBOARD" the radio/mic.
  Ver 1.3.0 - Tray time wrong
Posted by: HS0ZKM - 04-17-2013, 11:27 PM - Forum: BktTimeSync - Replies (4)
Thanks for the new version.
I have noticed that after a couple of days the time shown in the tray icon message is wrong although the clock itself is correct.
Victor
  CatBkt - Version 1.3.0
Posted by: iz2bkt - 03-21-2013, 09:22 PM - Forum: News / Novità - Replies (1)
- Added interface minimized.
- Improved color management.
- Added reset button position windows in Utility.
- Added in the TAB Utility the possibility to show/hide the PTT, Audio Recorder and the QuickSet.
Download from: http://www.iz2bkt.com/CatBkten_download.html
  Scan resume
Posted by: kc7ido - 03-19-2013, 05:27 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (2)
When using the "SCANNER" with in the software, it seems as if it disables the scan resume within the radio setting. Then when using scan from the radio it will not resume and just stay on current frequency. It would be a good idea to script a SCAN RESUME - ON code when exiting the scanner mode. This will save a lot of hassle in the future.
Thank you, KC7IDO
  CUT / PASTE multiple memory setting from Bank to Bank
Posted by: N9XY - 03-11-2013, 12:51 AM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (2)
I am trying to figure out if it is possible to CUT and then PASTE multiple memory settings from one bank to another.
I can CUT one entry and PASTE to another bank. This works great. But need to highlight several entries in one bank, cut and then past them all into another bank.
Is this possible? If not, I hope this could be a new feature to consider adding to the software.
Michael
N9XY
  How to load the registration key
Posted by: iz2bkt - 03-10-2013, 04:37 PM - Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori - No Replies
Method 1:
1. Unzip the registration key file received by email in the program folder (default: C:\IZ2BKT\IC706_BKT Icom CAT Control).
2. Run the program IC706_BKT, the key will be automatically loaded and deleted from the folder.
Method 2:
1. Unzip the registration key file <call.ic706_bkt.bkt> received by email in a folder.
2. Run the program IC706_BKT ( Version 4.0.5 or later, Free Key is not released for old versions )
3. On Utility tab click on [Register the program]
4. On registration dialog click on [I have the key, load it]
5. Select the unzipped file in the folder used in step 1 and press [Open]
6. At the next run the program will load the key into its database and delete it from the folder.
To check if the program is registered look in the title bar:
[Image: FreeVersion.png]
[Image: FullVersion.png]
