  Ultima versione BKT e yaesu 950
Posted by: i5wnn - 08-30-2014, 08:28 PM - Forum: Yaesu - Replies (9)
Ciao, ho scaricato l'ultima versione di bkt e ho visto i sospirati comandi per accendere e spengere l'apparato. Infatti il 950 (con vista) si accende e si spegne regolarmente ma, all'accensione, non effettua la sincronizzazione e allo spegnimento rimane tutto bloccato. Penso che il programma stia apettando qualcosa dalla radio ma non so cosa. Normalmente la com è impostata a 38000 ma lo steso accade con altre velocità.
  BktTimeSync version 1.5.1
Posted by: iz2bkt - 08-25-2014, 09:06 PM - Forum: BktTimeSync - Replies (1)
BktTimeSync Version 1.5.1 :
- Adding BktClock v.1.0.0
- Improved calculation of the coordinates and WWLocator
  Font settings
Posted by: kc7ido - 08-24-2014, 01:54 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (2)
I am not sure how I did it..... It seems as if the font setting was set to a size that is huge. I can NOT scroll the screen enough to get to the settings menu to reset the fonts at a normal size. This is leaving me with no way to use the program. Any suggestions would be welcome.
Future idea... A default button at the "TOP" would be a good fix for this.
Yes, I have tried to re-install...did not work.
Thanks, KC7IDO
  Clock will not sync with GPS trimble
Posted by: G3WDG - 08-19-2014, 12:09 PM - Forum: BktTimeSync - Replies (2)
New user of this software. NTP sync works fine but GPS does not. Help pse!
Log file attached - hopefully this will help. GPS is old trimble unit and data looks OK.
Log file was for setup with ntp, gps and if error NTP... all ticked. Switched pc wireless off to force a gps sync and got GetLastError 11004
Manually trying to Sync Now with NTP not ticked returns no notification.
  BKT Server audio
Posted by: EA6VQ - 08-18-2014, 06:07 PM - Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori - Replies (1)
I am testing the BKT server and the remote control of the rig works very well over internet, but I don' manage to hear the audio.
I have made the test of disabling audio in BKT server and using Skype to transmit the audio, and it works that way, so I know connections are OK. That is not the problem.
Any idea of what to try next? Something I must take into consideration?
Gabriel - EA6VQ
  BktTimeSync version 1.4.2
Posted by: iz2bkt - 08-14-2014, 08:06 AM - Forum: BktTimeSync - Replies (1)
BktTimeSync Version 1.4.2 :
- Correction of date also via GPS.
  CatBkt - Version 1.6.4
Posted by: iz2bkt - 08-13-2014, 07:53 PM - Forum: News / Novità - Replies (1)
- Adding function Power On and Power Off
- Include CatBktExtension 1.17.0
- Improved rtx comunication
Download from: http://www.maniaradio.it
  IC7100BKT Version 1.3.4
Posted by: iz2bkt - 08-09-2014, 04:26 PM - Forum: News / Novità - Replies (1)
Is available for download IC7100BKT Version 1.3.4 :
- Adding data mode
- Improved window of management of DV - DStar
- Correct setting remote data mode
- Include BktExtension71k ver. 1.17.0
- Fixed bug about displaying child windows (DV, PTT, Audio Recorder and Quick Set).
- Improved Power On and Power Off function.
  Richiesta di ulteriori funzioni
Posted by: I3EJ - 08-06-2014, 08:48 AM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (7)
Ciao Mauro, ho installato il tuo ottimo ic7100bkt che funziona egregiamente ed anche in coppia con BBlogger.
Mi pare pero' che ci siano un paio di funzioni importanti non ancora implementate (o forse sbaglio qualcosa io e non le ho trovate).
1) La più importante, direi essenziale: non trovo il modo di attivare il modo DATA. Ossia i modi USB-D, LSB-D, FM-D e AM-D. Questi modi sono indispensabili per poter usare la scheda audio interna al IC7100 per i modi digitali. Potrei attivarla dall'apparato ma al primo cambio di filtro da prog. mi ritorna ad es. da USB-D a USB.
2) Non ho provato tutti i vari comandi, ma sembra che la comunicazione da IC7100 a prog. riguardi solo la frequenza. Se vario qualcosa manualmente sull'apparato (tipo modo, filtro NR, ATT ecc.) la modifica non viene recepita dal programma.
Già ora il tuo prog. e' il più completo per gestire questo apparato, se riuscissi a sistemare queste due cosette sarebbe il top.
A presto e grazie, 73
Renato I3EJ
  DX Lab
Posted by: ve7wah - 08-03-2014, 05:48 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (2)
Has anyone been able to integrate DXLab with this program?
