| BktTimeSync 1.6.1 locks up, cannot open from Systray |
Posted by: W6DTW - 10-25-2014, 05:29 PM - Forum: BktTimeSync
- Replies (4)
I have been having trouble with the latest version 1.6.1.
BktTimeSync will eventually lock up and stop syncing time. At that point the app can no longer be accessed via right-click of the Systray icon. This happens when I'm in GPS-only or GPS+NTP config.
After the crash if I force quit Bkt from the process manager and relaunch, trying to turn off NTP and sync only to GPS time results in a rapid-fire succession of Systray notification messages. As in the other lock up, the Systray icon then becomes unresponsive. I can regain control of the PC by force quit of the process, but a reboot of the PC is required to regain ability to use GPS.
My setup:
ASUS EeePC running Windows 7 with latest patches
Garmin 18x USB GPS puck
Franson GPSGate Server
BktTimeSync 1.6.1
I activated Diagnostic Logging and was able to capture the post-relaunch glitch; that log is attached. I will continue to log and will post the unattended lock-up logfile once it happens.
| Bblogger su radio remota |
Posted by: iz0tws - 10-20-2014, 11:19 PM - Forum: BktRemote Suite
- Replies (3)
Innanzitutto grazie per questa fantastica serie di programmi che miha veramente cambiato la vita. Pure con settaggi disponibili inferiori ad Hrd mi sono evitato il lentissimo passaggio su Skype.
Una domanda.
Se uso bblogger su un pc come faccio a collegarlo con catbkt client? Ho il server funzionante perfettamente ed il client stand alone va bene. Ma non riesco a collegalo al bblogger
| Guida per utilizzare CatBkt con BBLogger |
Posted by: iz2bkt - 09-25-2014, 07:28 PM - Forum: General discussion - Problems - Bugs / Discussioni - Problemi - Errori
- Replies (17)
1. Installare CatBkt (lo potete scaricare da http://www.maniaradio.it)
2. Avviare e configurare CatBkt per il proprio RTX, è importante che CatBkt funzioni e riconosca la radio collegata
3. Avviare CatBkt
4. Avviare BBLogger
5. In BBlogger dal menù Strumenti cliccare BBLCAT (Multi Rig CATBKT)
A questo punto potete cliccare su uno spot del cluster di BBLogger e la radio verrà sintonizzata direttamente sulla frequenza della stazione spottata, oppure nell'inserimento di un Nuovo QSO cliccare sul tasto CAT BKT e frequenza e modo della radio verranno riportati nei relativi campi del QSO.
| IC-7410 +CatBkt Split & VFOs |
Posted by: OH2RA - 09-22-2014, 03:43 PM - Forum: Icom
- Replies (1)
All!
I am trying to see if CatBkt would access VFO-A/VFO-B change correctly on my IC-7410. It seems that A=B is not working, the only way to set split is to use the "Split Tab", selecting the split button on the UI doesn't allow for me access VFO-A and B such that I can set the split naturally as it is sitting at the radio.
Is this a problem with all ICOM radios? Icom RS-BA1 remote control SW has similar problems.
Thanks!
Markku OH2RA
| BktTimeSync non parte automaticamente con windows 8.1 ... |
Posted by: iw5bt - 09-13-2014, 07:31 PM - Forum: BktTimeSync
- Replies (6)
Ciao ,
Ho il tuo ottimo programma installato su due PC dove gira Windows 8.1.
Fino ad oggi tutto funzionava perfettamente ..... ma dopo gli ultimi aggiornamenti
non c'e' verso di farlo partire in automatico con il sistema .....
Probabilmente è cambiato qualcosa in windows .....
Se lo lancio manualmente funziona .... se lo faccio partire mettendolo nella cartella
avvio automatico non va , se pianifico l'esecuzione all'avvio del sistema non va ....
Qualche idea ?
Bye
Stefano
| BktTimeSync version 1.6.1 |
Posted by: iz2bkt - 09-10-2014, 07:59 PM - Forum: BktTimeSync
- Replies (1)
Is available for download:
BktTimeSync Version 1.6.1:
- Checking that the satellite is hooked
- Increased from 1KB to 4KB capacity of the monitor log
- Added support TSIP (thanks to Remy F6ABJ for support and test)
- If max hours of correction is equal to 0 always sets the time
- Improved BktClock configuration saving
- Added French language (thanks to Remy F6ABJ)
_________________
