  IC7000BKT Version 1.25.4
Posted by: iz2bkt - 12-19-2014, 08:17 PM - Forum: News / Novità - Replies (1)
IC7000BKT Version 1.25.4 :
- Improved copy/cut/paste of memories.
  IC7000BKT Version 1.25.3
Posted by: iz2bkt - 12-19-2014, 08:16 PM - Forum: News / Novità - Replies (1)
IC7000BKT Version 1.25.3 :
- Automatic restart after configuration.
  IC7100BKT Version 1.3.6
Posted by: iz2bkt - 12-19-2014, 08:14 PM - Forum: News / Novità - Replies (1)
Is available for download IC7100BKT Version 1.3.6 :
  IC7100BKT Version 1.3.5
Posted by: iz2bkt - 12-19-2014, 08:13 PM - Forum: News / Novità - Replies (1)
Is available for download IC7100BKT Version 1.3.5 :
  BKTtime- a comment
Posted by: sp7wt - 12-15-2014, 05:38 PM - Forum: BktTimeSync - Replies (2)
I use BKTtime for WSJT QSOs.
Just two qustions about this software:
# Is it possible to run this software ninimised to the background?
I do not see this option or am I missing something?
# I have a Bluetooth GPS receiver but a Bluetooth connection is often unstable.
Can this problem be rectified in next version of this software?
Tom, SP7WT
  Cut/paste problem
Posted by: vk3sf - 12-15-2014, 07:05 AM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (4)
I'm running version 1.25.3 and when I try to cut and paste a memory entry, the result is the cut line being deleted without the paste line being added. i.e. I lose the entry completely.
This has worked perfectly in previous versions - so I'm guessing it's a little bug Smile
Thanks for the program,
Ross.
  CatBkt and BKTRemoteServer
Posted by: DD8JM - 12-01-2014, 10:21 AM - Forum: Icom - Replies (4)
I have a problem:
I use IC7100bkt, there goes even so far everything.
Now I have my IC7400 connected and configuriert with CatBkt.
Here I have the IC746 specified because there is no ic7400 in the list.
I use a Samsung S4 when I go online and BKTRemoteServer connecte, I get an error message on the computer:
Command not supported in any way by this RTX.
I've tried various transceiver, IC756, IC756Pro, IC7000 there is always the same error message.
If I Acknowledge the error at the computer goes everything, even the voice goes well.
The meeting with the voice over is a good thing, I've tried many programs but this program makes it first. Otherwise, I've been using Skype for voice transmission.
What I have to say, the program leuft not very reliable, there are a few crashes, can I receive voice but not send.
Error come on even when the reproduced connection and new connection again.
There is no connection to conditions, I have to finish everything and reconnect again.
Otherwise everything is very good.
My english is very bad, I hope you have understood it as far as what my problem is. :oops:
Best regards from Germany
Joerg de DD8JM
http://www.saure.org
http://www.dd8jm.de
  Uso in CW con 706 mkIIg e SB2000 mk2
Posted by: ik8ioo - 11-26-2014, 04:06 PM - Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori - Replies (1)
Salve cari OM, spero di essere nella sezione giusta... stavo cercando di usare l'sb2000 mk2 in cw (con altri modi tutto ok) con il 706mkIIg, ma credo non vada come dovrebbe... in tx va, ma non vedo nel waterfall la mia emissione, cerco qualcuno che abbia il mio stesso setup e mi possa aiutare sulla giusta config.
Grazie per l'entuale aiuto.... Giovanni IK8IOO
IC-706mk2g
SB2000 mk2
HRD DM780 5.24.038
  TS 2000 e CAT BKT - Nuovo PC
Posted by: IZ1SAI - 11-19-2014, 07:49 AM - Forum: Keenwood - Replies (2)
Buongiorno,
ho cambiato PC e passato da un Core I2 a un Core I7.
Quest'ultimo ha la bellezza di 8 porte usb, di cui 3 Usb 3.0
Per collegare il Ts2000 al Pc ho sempre usato le 2.0.
1)C'e' differenza in un discorso di Cat usare 2.0 o 3.0?
2)Come vengono viste queste porte USB sul tuo programma? Come COM1 sembrerebbe...ma perchè come collegamento propone sempre e solo Seriale anche se è USB?
Non riesco a far vedere l'apparecchio, neppure settando a 9600 come per il vecchio PC. Help me!
grazie mille
IZ1SAI
  Come caricare la chiave di registrazione
Posted by: iz2bkt - 11-16-2014, 10:49 AM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - No Replies
Metodo 1:
1. Scomprimere il file di registrazione ricevuto via email nella cartella di installazione del programma (predefinita: C:\IZ2BKT\IC7100BKT Icom CAT Control)
2. Avviare il programma IC7100BKT, la chiave sarà caricata automaticamente e cancellata dalla cartella
Metodo 2:
1. Scomprimere in una cartella il file <call.ic7100bkt.bkt> ricevuto via e-mail.
2. Avviare il programma IC7100BKT.
3. Nella scheda Utilità, cliccare su [Registra il programma].
4. Nella maschera di registrazione, cliccare su [Caricare la chiave].
5. Selezionare il file scompresso nella cartella usata al punto 1 e premere [Apri].
6. Al prossimo avvio il programma caricherà la chiave nel suo database e la cancella dalla cartella.
Per controllare se il programma è registrato guardare nella barra del titolo:
[Image: FreeVersion.png]
[Image: FullVersion.png]
