  Problem with Win 8.1 startup
Posted by: BlueAstro - 03-25-2015, 01:08 AM - Forum: BktTimeSync - Replies (3)
Mauro and others, I have a Win 8.1 laptop that I have loaded this time sync program onto.
I also have another PC that I built that runs Win 7 Pro with this time sync program.
The Win 7 PC when it boots up runs this program on start up as normal and the icon
shows in the system tray and syncs on start up.
The problem is with the 8.1 64 bit laptop, upon start up the program will not run.
I have installed it via run as administrator, the box is checked, start on windows start up
and start on system tray and sync on start up.
I created a scheduled task to have it run at start up, but even that task it will not run at start up.
I have the latest version 1.7.
In Kaspersky it is listed as trusted in the programs manager and everything is green to run.
The only way to run it is manually clicking on the shortcut, when this happens the user account control
pops up with yes or no, clicking yes runs the program. I also have copied and placed the .exe time sync
into the start up folder to try and have it run at start up, but no go.
In the BktTimeSync Properties Security tab, every group or users has permissions to allow, checked
in every category except for Special permissions.
In task manager Start up tab, the status is Enabled.
At this point, what is missing? Is it being blocked? When it runs it syncs just fine.
I have the Windows Time Sync disabled to avoid conflict as I have done on the Win 7 PC.
I disabled the user account control and did a restart but again no go to run this program on start up.
Has anyone had this problem on a Win 8.1 system?
Bruce
  SDR
Posted by: kd7jwc - 03-11-2015, 11:26 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (2)
Would there be a way to have spectrum analysis similar to what we get with software like SDR# or HDSDR. I would like to be able to see the full band and then be able to just click on the band spot where there is activities. Thank you.
KD7JWC
  ft 450 D
Posted by: IZ3TJC - 03-06-2015, 06:30 PM - Forum: Yaesu - Replies (4)
73,
sto provando a configurare un ft 450 D , ma non c'è verso di farlo andare, invece con un ft 857 si è configurato al volo.
Forse non è supportato il 450 d ma solo il 450? Grazie
  VSEND SEL
Posted by: it9bgi - 03-05-2015, 07:42 AM - Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori - Replies (2)
Buongiorno,
ho la necessità di variare l'item 30 "VSEND SEL" del menù del 706 da "on" a "off".
Posso farlo attraverso questo SW visto che l'apparato è ubicato in altre sede e lo potrei controllare con un pc con un desktop remoto?
Grazie a buona giornata.
Salvo IT9BGI
  Quickset
Posted by: G0IIQ - 03-04-2015, 12:26 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (4)
When using quickset if I click on one of the buttons for a local repeater the frequency and everything changes correctly but after approximately 2 seconds the S meter on the rig and the software show a full reading and there is a loud hissing from the Icom IC7000 just fractionally turning the Volume up or down on the Rig rectifies the problem
  Testing the Server without IC700 connected?
Posted by: DH1EAR - 02-28-2015, 04:06 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (2)
Hallo,
is there a way to test the server without a IC7000 is just connected to the Server PC?
I just try to test if i can reach the connection via the internet.
Tnx for any help.
Kind regrds.
Mark
  Reload IC7000BKT program
Posted by: herbpk - 02-16-2015, 03:43 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (1)
I have been utilizing the IC7000BKT program for years with much success / enjoyment. Primarily, my interest has been in remote operations where I utilize a combination of Team Viewer / Skype / IC7000BKT to control and access the Icom radio.
I retired the host computer which was running Windows XP in favor of a new computer with Windows 7, 64 bit. I ran into problems from the beginning: many audio issues from remote and the program crashing when I am at the host. Frequency changing randomly and no ALC registering even when I am transmitting. I have decided the only avenue is to do a fresh installation of the program. Could anyone let me know the best way to completely uninstall IC7000BKT from my Windows 7 machine?
I also notice one additional item which I do not remember: I seem to be unable to "turn off" the antenna tuner from the program. The best I can do is "re-tune" and antenna from the interface and cannot simply turn off the tune function. I am not sure what I am doing wrong.
Thanks for any assistance.
  BktTimeSync Version 1.7.0
Posted by: iz2bkt - 02-14-2015, 10:27 AM - Forum: BktTimeSync - No Replies
Is available for download:
BktTimeSync Version 1.7.0:
- Added support for NMEA 4.0 format
- Added UTC option in BktClock
http://www.maniaradio.it
  Glonas GPS support
Posted by: pjm - 02-11-2015, 07:09 AM - Forum: BktTimeSync - Replies (8)
I've been using BktTimeSync for a while now, with no issues, but I've just upgraded my GPS received to one that supports both GPS and Glonas satellites. I have noticed some of the NMEA sentence information is different with this receiver and it seems to have confused BktTimeSync. It still detects my location but it doesn't seem to pick up the date/time from the NMEA data.
e.g. it sends strings
$GNGLL
$GNGSA
instead of
$GPGLL
$GPGSA
I must admit there are a number of options I can set with this new GPS and I don't understand them all.
[Image: wbtsFKs.jpg]
Just wondering if BktTimeSync can be updated to work with the new receivers.
I've tried to attached an NMEA log from the new receiver to this post, not sure if it made it I can't see it in the post
  IC7100BKT Version 1.4.1
Posted by: iz2bkt - 02-04-2015, 08:58 PM - Forum: News / Novità - Replies (1)
Is available for download IC7100BKT Version 1.4.1 :
- After a software tune is set correctly the Data mode.
