  info
Posted by: Iv3gde - 08-19-2015, 08:12 PM - Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori - Replies (2)
Ho visto che per il 706 e anche per il cat manca la parte cw . Hai dovuto sopperire cosi' il il plugin in quanto non c' era la possibilita'
di falco via ci-v ?
Thanks Alx
  bktkeyercw
Posted by: Iv3gde - 08-19-2015, 06:56 PM - Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori - Replies (2)
Solo segnalo (non importante) che una volta installato il plugin la GUIDA va in errore
"FAILED TO LAUNCH HELP"
Ottimo comunque per il supporto del cw.
Alx
  IC7100BKT Version 1.6.0
Posted by: iz2bkt - 08-19-2015, 08:42 AM - Forum: News / Novità - Replies (1)
Is available for download IC7100BKT Version 1.6.0 :
- Improved AutoCQ
- In tab Set Mode, adding the manage input of the modulation
  Bkt Server crash and won't start
Posted by: pezcat19 - 08-17-2015, 07:07 AM - Forum: BktRemote Suite - Replies (4)
I am attempting to run BktRemote Server on an WinXP SP3 PC but I am having a problem. I have the CatBkt working successfully with a Yaesu FT2000. All ports and IP is working fine.
The problem is that the BktRemote Server application will not launch after the first installation. It works for the first time, but if it crashes or if you restart the PC, BktRemote Server will not open again. Clicking on the BktRemote Server icon launches the CatBkt application but NOT the BktRemoteServer application - it does not start. In the task manager I can see the BktRemoteServer.exe process, but it is not working and I can not open the user interface, or connect to it. If I force close the active processes, it still will not open. (There is also NO taskbar / tray icon).
Can you offer me any advice please? I really want to have the server working and stable for my Android client.
(Also, PLEASE offer a paid, No ADS app!) I HATE the ads!
Cheers, Pez
  modulazione e cw
Posted by: Iv3gde - 08-16-2015, 07:49 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (10)
il bkt7100 dal mio punto di vista presenta 2 problemi/mancanze :
1) Affiche’ quando uso l’ autocq l’ apparato moduli devo necessariamente mettere da menu’ sull’ apparato che la modulazione enta fa USB. Ma facendo cio’ il microfono e’ inutilizzabile .Come faccio a rispondere dopo un autocq? Dovrei reimpostare dal menu’ settaggi che la modulazione arriva da microfono ( esistono, ho verificato i codici cv i per fare i settaggi via software, prima del autocq metti input usb e finito l’ autocq input microfono) Faccio software, per cui se ti serve una mano parliamone lo faccio gratuitamente.
2) Non e’ possibile avere un autocq per il CW ? Per me’ e’ scomodo prima programmare le memorie ( si puo’ fare…) ma poi per fare l’ autocq in cw devo andare fisicamente sui comandi della radio, non si puo’ fare tutto via software ?
Ringraziandoti porgo distinti saluti
Alessio iv3gde
  Error in CW & SSB Filters
Posted by: EA5SW - 07-27-2015, 06:40 AM - Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori - Replies (7)
I have the CW & SSB filters installed in my 706Mk2G, the filter selection is made bad with the filter button,in cw modes the filter selected is W and never switch to the narrow filter.
The OP filter 1 is FL-101 and the Op filter 2 is FL-223
It's possible to solve this issue ??
Greetings
Jose
EA5SW
  Settaggio audio
Posted by: IW8ELK - 07-22-2015, 09:54 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (1)
Perchè non riesco a settare l'uscita audio e l'ingresso microfonico? allego foto
  CatBkt Version 1.8.1
Posted by: iz2bkt - 07-19-2015, 04:31 PM - Forum: News / Novità - Replies (1)
- Support BKTExtension 1.18.0
Download from http://www.maniaradio.it/en/catbkten_download.html
  IC706_BKT Version 4.17.1
Posted by: iz2bkt - 07-19-2015, 04:30 PM - Forum: News / Novità - Replies (1)
Is available for download IC706_BKT Version 4.17.1 :
  IC7000BKT Version 1.27.1
Posted by: iz2bkt - 07-19-2015, 04:29 PM - Forum: News / Novità - Replies (1)
Is available for download IC7000BKT Version 1.27.1 :
