| CatBkt Version 1.15.x |
Posted by: iz2bkt - 01-05-2025, 10:42 AM - Forum: News / Novità
- No Replies
CatBkt Version 1.15.4
- Improved compatibility with HamLib 4.6
CatBkt Version 1.15.3
- Restoration of Custom Key functionality with HamLib 4.6.
- Minor bug fixes.
CatBkt Version 1.15.2:
- Solved connection issue with non-Icom transceiver
CatBkt Version 1.15.1:
- Disabling the LAN protocol prevents the TCP server from starting, thus avoiding unnecessary resource consumption.
CatBkt Version 1.15.0:
- Update to HamLib 4.6
- Added LAN protocol compatible with DX Commander by DXLabs (Replaces BktNetInterface)
- Several improvements
| APERTURA PROGRAMMA |
Posted by: DANTE - 12-19-2024, 10:35 AM - Forum: General discussion - Problems - Bugs / Discussioni - Problemi - Errori
- Replies (2)
ciao Mauro
utilizzavo il programma CATBKT con alinco sr8 funzionava benissimo non saprei cosa ho fatto se aggiornando il programma oppure il PC
mi ritrovo con icona picolissima sul monitor e non riesco piu a ingrandire e le finestre che si aprono del programma sono enormi e non riesco a ridurre il mio sistema windos 7 64 bit chi mi può aiutare ringrazio.
73 ik2lhr
| Client Server Mode |
Posted by: iz2bkt - 11-22-2024, 09:40 AM - Forum: BktTimeSync
- No Replies
From version 1.14.x, BktTimeSync allows you to synchronize time between a server and one or more clients. When configured as a server, BktTimeSync synchronizes its own time using NTP or GPS, then provides the time to connecting clients. When configured as a client, BktTimeSync disables local NTP/GPS synchronization and connects to the server to synchronize the time.
Server Mode
• Role: Provides time to clients and synchronizes its own time using NTP or GPS.
• Steps:
1. Configure the time synchronization option (NTP or GPS).
2. Set the port on which the server will listen for client requests.
3. Press the Start button to start synchronizing its own time and accepting connections from clients.
Client Mode
• Role: Receives time from the server and applies it locally.
• Steps:
1. Enter the IP address and port of the server to connect to.
2. Disable any local NTP or GPS synchronizations (the program does this automatically).
3. Press the Test button to verify the connection to the server.
Server Mode - Configuration and Startup
• Choosing the synchronization source:
Select between NTP or GPS as the method to synchronize the server's time. • NTP: Enter the address of an NTP server. • GPS: Configure the associated GPS device.
• Listening port:
• Specify the port on which the server will listen for client requests. Ensure that this port is open in the firewall.
• Startup:
1. Press Start.
2. Once started, the server will wait for connections from clients on the configured port.
Client Mode - Configuration and Startup
• Server configuration:
1. Enter the IP address or hostname of the server you want to connect to.
2. Enter the server port (the one configured in server mode).
• Disabling local synchronization:
• The program automatically disables any active NTP or GPS synchronizations on the client.
Troubleshooting
The client cannot connect to the server:
1. Verify that the IP and port are correct.
2. Check that the firewall allows connections on the configured port.
3. Make sure the server is running.
The client does not update the time:
1. Check that the server is sending the correct time.
| Modalità Client Server |
Posted by: iz2bkt - 11-22-2024, 09:30 AM - Forum: BktTimeSync
- No Replies
Dalla versione 1.14.x BktTimeSync consente di sincronizzare l'orario tra un server e uno o più client. Quando configurato come server, BktTimeSync sincronizza il proprio orario tramite NTP o GPS, quindi fornisce l'orario ai client che si connettono. Quando configurato come client, BktTimeSync disabilita la sincronizzazione NTP/GPS locale e si collega al server per sincronizzare l'orario.
Modalità Server
• Ruolo: Fornisce l'orario ai client e sincronizza il proprio orario tramite NTP o GPS.
• Passaggi:
1. Configurare l'opzione di sincronizzazione dell'orario (NTP o GPS).
2. Impostare la porta sulla quale il server ascolterà le richieste dai client.
3. Premere il pulsante Avvia per iniziare a sincronizzare il proprio orario e ad accettare connessioni dai client.
Modalità Client
• Ruolo: Riceve l'orario dal server e lo applica localmente.
• Passaggi:
1. Inserire l'indirizzo IP e la porta del server a cui collegarsi.
2. Disabilitare eventuali sincronizzazioni locali NTP o GPS (il programma lo fa automaticamente).
3. Premere il pulsante Prova per verificare la connessione con il server.
Modalità Server - Configurazione e Avvio
• Scelta della fonte di sincronizzazione:
1. Seleziona tra NTP o GPS come metodo per sincronizzare l'orario del server.
• NTP: Inserisci l'indirizzo di un server NTP.
• GPS: Configura il dispositivo GPS associato.
• Porta di ascolto:
• Specifica la porta sulla quale il server ascolterà le richieste dei client. Assicurati che questa porta sia aperta nel firewall.
• Avvio:
1. Premere Avvia.
2. Una volta avviato, il server attenderà connessioni dai client sulla porta configurata.
Modalità Client - Configurazione e Avvio
• Configurazione del server:
1. Inserisci l’indirizzo IP o il nome host del server a cui vuoi collegarti.
2. Inserisci la porta del server (quella configurata in modalità server).
• Disabilitazione sincronizzazione locale:
• Il programma disabilita automaticamente eventuali sincronizzazioni NTP o GPS attive sul client.
Risoluzione dei Problemi
Il client non riesce a connettersi al server:
1. Verifica che l’IP e la porta siano corretti.
2. Controlla che il firewall permetta le connessioni sulla porta configurata.
3. Assicurati che il server sia avviato.
Il client non aggiorna l’orario:
1. Controlla che il server stia inviando l’orario corretto.
| Virtual com port not working |
Posted by: fmgkamps - 06-18-2024, 09:29 AM - Forum: BktTimeSync
- Replies (3)
I am using a Getac rugged laptop with an integrated GPS which is internally available on COM2. On the Getac laptop VGPS software is standard installed which has the possibility to share the GPS data on max 5 virtual com ports.
If the VGPS software is disabled the BktTimeSync software is working fine on COM2, however if the VGPS software is enabled the BktTimeSync software is not working on any of the virtual come ports created by VGPS. All other software which uses GPS works fine on the virtual com ports, including the timesync software GPS2Time developed by VK4ADC.
Is there a workaround for this issue?
Regards, Frank (PE0FK)
