| BktTimeSync v1.20.xx (SOLVED) |
Posted by: Brad Williams - 05-27-2025, 02:15 PM - Forum: BktTimeSync
- Replies (5)
I've been using BktTimeSync for quite some time. Current working version is v1.15.0. I installed v1.20.0 and the GPS sync did not work and gave a "GPS time invalid". I then tried the latest v1.20.1 and still got "GPS time not valid". I tried uninstalling v1.15.0 and installing v1.20.1 but get the same issue. Disconnecting the GPS and re-connecting did not resolve the issue.
Any thoughts ??
PS: Running Windows 10Pro
Brad, K8ZM
| BktTimeSync Version 1.20.x |
Posted by: iz2bkt - 05-21-2025, 06:03 AM - Forum: BktTimeSync
- No Replies
Is available for download:
BktTimeSync Version 1.20.6:
- Improved BktClock
BktTimeSync Version 1.20.5:
- Improved GPS communication over serial port
- Improved BktClock
BktTimeSync Version 1.20.4:
- Fixed bug that halved the potential NTP server time correction offset
- Improved BktClock configuration
BktTimeSync Version 1.20.3:
- Improved interface localization system
- Added Czech translation thanks to Miloš, OK1FMY
BktTimeSync Version 1.20.2:
BktTimeSync Version 1.20.1:
- Restoring BktClock
- Various improvements
BktTimeSync Version 1.20.0:
- Unicode support
- Improved NTP protocol
- Ability to set maximum error and correction even when using BktTimeSyncGPS
- Added German, Polish, and Portuguese translations
| BKTIMESYNC with Windows 11 PRO. |
Posted by: XE1R - 03-21-2025, 04:04 PM - Forum: BktTimeSync
- Replies (1)
I have the problem that in WINDOWS 11 PRO the BKTIMESYNC I have not been able to start when opening the windows or turning on the PC. I have used it in WINDOWS 8.1, 10 and 11 Home and if it opens without a problem.
Obviously enabling the functions of Start on Windows Startup, Start on system Tray, Sync on starup.
This is only on WINDOWS 11 PRO. What can I do?
I have installed the latest version which is 1.14.0
Has anyone had the same problem?
Thank you in advance
Joki XE1R
| IC7000BKT Freezing |
Posted by: herbpk - 02-11-2025, 10:30 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori
- Replies (3)
Gentleman/Mania Radio:
Thanks for many years of excellence performance with the IC7000BKT program, which I am using with Windows 10 OS.
Now, unexpectedly, the IC7000BKT program is freezing. Initially, the startup of the program is as always: works for many
seconds and then freezes up. I can "re-boot" and re-establish the connection, but it freezes again after a short time.
I have upgraded the version to 1.31.3. No difference in the freezing.
I have tried uninstalling the previous program and re-installing: no difference.
All help will be appreciated.
N2GEW
Herb
