  bkttimesync restarts randomly
Posted by: kf5tfj - 12-24-2013, 12:02 PM - Forum: BktTimeSync - Replies (8)
I've noticed that lately, the program flashes a message that it is restarting. What is going on?
Does not seem to be a problem, but I have noticed multiple icons for the program in the taskbar. They seem to clear themselves.
  BktTimeSync version 1.4.0
Posted by: iz2bkt - 12-08-2013, 03:38 PM - Forum: BktTimeSync - Replies (2)
BktTimeSync Version 1.4.0 :
- Improved GPS section.
  Further to my last regarding Sync getting GPS error
Posted by: kf5tfj - 12-05-2013, 03:28 PM - Forum: BktTimeSync - Replies (1)
Here is the diagnostic log:
Windows Versione: 6.01
BKTTimeSync Versione: 1.3.0
NTP Server: time.nist.gov
NTP Porta: -1
NTP Offset:
NTP ON: 0
Autostart: 1
Start in tray: 1
Sync all'avvio: -1
Sync ogni: 5 minuti
Sync massima: 12 ore
GPS Porta: 6
GPS Baud: 115200
GPS Bit: -1
GPS Bit di stop: -1
GPS Parità:
GPS RTS: 0
GPS DTR: 0
GPS Offset:
GPS ON: 1
Sequence: 1
12/05/13 08:13:30 --> Sync start P1
12/05/13 08:13:30 --> Sync GPS COM open
12/05/13 08:13:30 --> GPS rx str P1
12/05/13 08:13:30 --> GPS rx str: $GPTXT,01,01,02,u-blox ag - <!-- w --><a class="postlink" href="http://www.u-blox.com*50">www.u-blox.com*50</a><!-- w -->
12/05/13 08:13:30 --> GPS rx str: $GPTXT,01,01,02,HW UBX-G5xxx 00040005 *1B
12/05/13 08:13:30 --> GPS rx str: $GPTXT,01,01,02,EXT CORE 5.00 (31155) Dec 8 2008 14:21:54*41
12/05/13 08:13:30 --> GPS rx str: $GPTXT,01,01,02,ROM BASE 5.00*13
12/05/13 08:13:30 --> GPS rx str: $GPTXT,01,01,02,ANTSUPERV=AC SD PDoS SR*20
12/05/13 08:13:30 --> GPS rx str: $GPTXT,01,01,02,ANTSTATUS=OK*3B
12/05/13 08:13:30 --> GPS rx str: $GPRMC,141331.00,A,2933.17215,N,09539.35838,W,0.658,345.32,051213,,,A*7D
12/05/13 08:13:30 --> GPS rx str: $GPVTG,345.32,T,,M,0.658,N,1.219,K,A*3E
12/05/13 08:13:31 --> GPS rx str P1
12/05/13 08:13:31 --> GPS rx str: $GPGGA,141331.00,2933.17215,N,09539.35838,W,1,07,1.33,15.7,M,-24.0,M,,*5D
12/05/13 08:13:31 --> Sync GPS OK, next to :12/05/13 08:18:49
12/05/13 08:13:31 --> GPS rx str: $GPGSA,A,3,12,04,17,10,02,28,24,,,,,,2.92,1.33,2.60*00
12/05/13 08:13:31 --> Sync GPS COM port closed
12/05/13 08:18:49 --> Sync start P1
12/05/13 08:18:49 --> Sync GPS ERROR in opening the COM port
12/05/13 08:18:50 --> Sync start P1
12/05/13 08:18:50 --> Sync GPS ERROR in opening the COM port
12/05/13 08:18:51 --> Sync start P1
12/05/13 08:18:51 --> Sync GPS ERROR in opening the COM port
12/05/13 08:18:52 --> Sync start P1
12/05/13 08:18:52 --> Sync GPS ERROR in opening the COM port
12/05/13 08:18:53 --> Sync start P1
12/05/13 08:18:53 --> Sync GPS ERROR in opening the COM port
12/05/13 08:18:54 --> Sync start P1
12/05/13 08:18:54 --> Sync GPS ERROR in opening the COM port
12/05/13 08:18:55 --> Sync start P1
12/05/13 08:18:55 --> Sync GPS ERROR in opening the COM port
12/05/13 08:23:06 --> Sync GPS ERROR in opening the COM port
12/05/13 08:23:07 --> Sync start P1
12/05/13 08:23:07 --> Sync GPS ERROR in opening the COM port
12/05/13 08:23:08 --> Sync start P1
12/05/13 08:23:08 --> Sync GPS ERROR in opening the COM port
12/05/13 08:23:09 --> Sync start P1
12/05/13 08:23:09 --> Sync GPS ERROR in opening the COM port
  Loses connectivity with USB
Posted by: kf5tfj - 12-05-2013, 01:44 PM - Forum: BktTimeSync - Replies (6)
I'm using the GPS to keep my PC clock on track for JT65-HF. However, I get occasional messages that the USB connection is lost, and I have to close bkttimesync and reopen it to restore the connection. I have power settings set to keep the USB alive, and thought that would cure the problem.
Anything else I should try, or is it something with the program?
I'm using Win 7 64bit Home Premium. Hardware is 2013 MacMini with 16Gb and native Windows boot. The GPS is a ublox 5 from Microsoft Streets and Trips. I can usually see 8 or more sats with this device...
IZ2BKT: How was the coffee?
  Mode-A/B not working on HF
Posted by: mdblack98 - 09-30-2013, 02:22 PM - Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori - Replies (4)
Tried to set an HF channel 7.215Mhz on LSB.
So I've got
VFO-A 7.215,000
Mode-A LSB
Filter-A Off
VFO-B 7.215,000
Mode-B LSB
Filter-B Off
Split NOSPLIT
DUP NODUP
Tone OFF
TSQL Off
Tone blank
Sync with the radio....but when I select the channel from the radio or through bkt is comes up FM.
If can select LSB from the bkt control panel...just doesn't work from memory chanells.
I'm on version 4.13.1
Mike W9MDB
  BKT server II - Norton issue
Posted by: kc7ido - 09-28-2013, 11:00 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (6)
When ever I try to download the BKT Server II, my Norton antivirus is completely stopping and deleting the software with a dangerous warning and preventing any form of download at this point. What next?
  Missing BKT server
Posted by: kc7ido - 09-23-2013, 10:35 PM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (1)
I am trying to setup for remote control, but I can not find BKT server anywhere. I have look online, and in the program files on the hard drive. How do I get BKTserver?
  remote control
Posted by: kc7ido - 09-23-2013, 01:21 AM - Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori - Replies (3)
It has been a long time sinse I have used the remote control. I see many things have changed. How do it set up for this. I am going to use LAN for the linking. A lynksys RG45 with desktop as main computer running the radio. and a laptop with wireless card...I am at a total loss as what to do anymore.
Step by step instructions would be great.
My email is <!-- e --><a href="mailto:kc7ido@gmail.com">kc7ido@gmail.com</a><!-- e -->
Thank you
  Error in getting sync
Posted by: G4FUT - 06-19-2013, 09:35 PM - Forum: BktTimeSync - Replies (3)
BkTimesyn has been working for me for some months now without problems. However today I cannot get a syn and get this error
Failed to retreive time from NTP server ntp1.inrim.it on port 123, GetLastError returned 10060
Any advice please?
Regards
Jon G4FUT
  GPS compatibility?
Posted by: W4IWK - 05-31-2013, 05:22 PM - Forum: BktTimeSync - Replies (2)
Are there any compatibility problems with any of the cheap USB GPS receivers on eBay, etc? (I intend to use it with jt65-hf.)
Any critical specs other than SIRF III?
Is there a recommended brand or model?
Irv W4IWK
