GPS Coordinates no longer shown? [SOLVED]
I am running BktTimeSynch Ver 1.11.0 and Win7 Pro - 64.
When running on GPS I no longer get Coordinates, Altitude and WW Indicator displayed? The GPS synchs correctly and provides excellent time.
Is this a bug in 1.11.0?
73, Rick
VE7TK
With my GPS it works, please, enable the diagnostic Log and post it.
Thank you
[Image: BktTimeSync_coordinateOK.png]
(05-07-2019, 05:13 PM)Rick Wrote: I am running BktTimeSynch Ver 1.11.0 and Win7 Pro - 64.
73, Rick
VE7TK
Here is the file you requested.  I believe it includes the startup AND a manual synch. Also it looks like the Lat , Long and Elevation info are correct.
Thanks,
Rick
VE7TK
Windows Versione: 6.01
BKTTimeSync Versione: 1.11.0
NTP Server: tick.usask.ca
NTP Porta: -1
NTP Offset:
NTP ON: 0
Autostart: -1
Start in tray: 1
Sync all'avvio: -1
Sync ogni: 10 minuti
Sync massima: 12 ore
GPS Porta: 16
GPS Baud: 4800
GPS Bit: -1
GPS Bit di stop: -1
GPS Parità:
GPS RTS: -1
GPS DTR: -1
GPS Offset:
GPS Always Connected: -1
Sequence: 1
Wed May  8 10:37:28 2019 -->
NTP Porta: -1
NTP Offset:
NTP ON: 0
Autostart: -1
Start in tray: 1
Sync all'avvio: -1
GPS Porta: 16
GPS Baud: 4800
GPS Bit: -1
GPS Bit di stop: -1
GPS Parità:
GPS RTS: -1
GPS DTR: -1
GPS Offset:
Sequence: 1
Wed May  8 10:37:32 2019 --> Sync start P1
Wed May  8 10:37:33 2019 --> GPS rx str P1 - BuffLen=68
Wed May  8 10:37:33 2019 --> GPS rx str: $GPRMC,173733.00,A,4828.98430,N,12322.35256,W,0.026,,080519,,,D*63
Wed May  8 10:37:33 2019 --> Sync GPS OK, next to :Wed May  8 10:47:00 2019Wed May  8 10:39:36 2019 --> Sync start P1
Wed May  8 10:39:36 2019 --> GPS rx str P1 - BuffLen=68
Wed May  8 10:39:36 2019 --> GPS rx str: $GPRMC,173937.00,A,4828.98271,N,12322.35139,W,0.036,,080519,,,D*61
Wed May  8 10:39:37 2019 --> Sync GPS OK, next to :Wed May  8 10:49:00 2019Wed May  8 10:39:51 2019 -->
It is working again? I have no idea what has changed but for some reason the Lat, Long, Elevation and Grid are back??
Thanks for your help Mauro.
73, Rick
VE7TK
The problem occurs when the GPS first sends the $GPRMC string of the $GPGGA.
The BktTijmeSync 1.11.1 version solves this problem.
Working again. However, the Altitude is not showing? (Since the Altitude on my cheap GPS is inaccurate I do not miss it - hi!)
Thanks again Mauro.
73, Rick
VE7TK
The altitude is present only in the $GPGGA string which is sometimes not passed
(05-10-2019, 07:39 PM)iz2bkt Wrote: The altitude is present only in the $GPGGA string which is sometimes not passed
Thanks Mauro. I just checked again and after a few hours of operation Altitude is indeed on the screen.
Thanks.
73, Rick
VE7TK
Users browsing this thread: 5 Guest(s)
