IC7100BKT Software freezes after 2 minutes of use
Video
Hello, I am using the IC-7100BKT software. When I start the software I can work with it for a maximum of 2 minutes, after which the software freezes and I can only exit and restart it via the Task Manager, but then the problem is there again after a short time.
The error occurs on different Windows systems and different computers.
I tested it on Windows 7 Pro 64bit and on Windows 10 Pro 64bit. Does anyone have any idea why this might be ? Wanted to use the BKT Remote Suite, only for this the IC-7100BKT software has to run properly.
(08-29-2021, 01:15 PM)DAA974 Wrote: Hello, I am using the IC-7100BKT software. When I start the software I can work with it for a maximum of 2 minutes, after which the software freezes and I can only exit and restart it via the Task Manager, but then the problem is there again after a short time.
go to COM port configuration and change the mode from 1 to 2 or vice versa
