IC7100BKT Software freezes after 2 minutes of use - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: IC7100BKT Cat Control for Icom IC-7100 (https://www.maniaradio.it/forum/forumdisplay.php?fid=15) +--- Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=24) +--- Thread: IC7100BKT Software freezes after 2 minutes of use (/showthread.php?tid=521) |
IC7100BKT Software freezes after 2 minutes of use - DAA974 - 08-29-2021 Hello, I am using the IC-7100BKT software. When I start the software I can work with it for a maximum of 2 minutes, after which the software freezes and I can only exit and restart it via the Task Manager, but then the problem is there again after a short time. The error occurs on different Windows systems and different computers. I tested it on Windows 7 Pro 64bit and on Windows 10 Pro 64bit. Does anyone have any idea why this might be ? Wanted to use the BKT Remote Suite, only for this the IC-7100BKT software has to run properly. RE: IC7100BKT Software freezes after 2 minutes of use - iz2bkt - 08-30-2021 (08-29-2021, 01:15 PM)DAA974 Wrote: Hello, I am using the IC-7100BKT software. When I start the software I can work with it for a maximum of 2 minutes, after which the software freezes and I can only exit and restart it via the Task Manager, but then the problem is there again after a short time. Hi, go to COM port configuration and change the mode from 1 to 2 or vice versa |
