Installation and Configuration
Unable to configure and get running. Program hangs.
Configuration details:
Dell XPS M1330 ; Intel Duo CPU ; T8300@2.4GHz; RAM 4 GB ; Windows 7; 32 Bit; SP1;
Interface: RigTalk RT1-USB version of the Icom CT-17 Serial Interface; COM 5; Setting 19.2, 8N1N; Driver WMR, 21.07.2010, version 6.1.0.0;
PROBLEM: IC7000BKT version 1.19.1; Run ic7000bkt_Setup.exe; Run IC7000BKT Icom CAT Control; Program Hangs, 8 bars in ’Initialization in process’ window; Status 5038; allow program another few minutes to initialize; can only close with ‘Task Manager’;
RETRY: check port config, then RUN ic7000bkt_Setup.exe; Hangs the same; Status2037………….. Tried several times and get Status of 6293, 2060, 4025, ………………
De-Install 1.19.1; clear C: of IZ2BKT folder and its IC7000BKT Icom CAT Control; Re-Start PC Folder; Install version 1.14.2; Failure the same; Status 5039; ………………………
RETRY: check port config, then RUN ic7000bkt_Setup.exe; Hangs the same; Status2037………….. Tried several times and get Status of 6293, 2060, ………………
De-Install 1.14.2; clear C: of IZ2BKT and its IC7000BKT Icom CAT Control; Re-Start PC; Install version 1.19.1; Failure the same; ………………………
Other programs, Commander v 5.8.7 seem to function correctly. I am not aware of and appropriate reference program.
Thanks for the assistance, Mike, HB9DHY
It seems to be a connection problem radio-> pc.
Have you tried this: http://www.iz2bkt.com/forum/viewtopic.php?f=5&t=6, in particular tries to change from mode 1 to mode 2 or vice versa.
The program must NOT be installed in "Program Files".
I recreated your condition and saw that the RigTalk has some problems, while trying to solve, use this configuration:
Disable Polling, Configure COM: Mode 2, 19200,8,N,1 RTS=ON DTR=ON
If you still have problems put the Latency to 200 or 300 (in the configuration window).
Now I work to solve the problem with RigTalk.
Install version 1.19.2
Users browsing this thread:
