Installation and Configuration - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: IC7000BKT Cat Control for Icom IC-7000 (https://www.maniaradio.it/forum/forumdisplay.php?fid=5) +--- Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=7) +--- Thread: Installation and Configuration (/showthread.php?tid=119) |
Installation and Configuration - HB9DHY - 02-04-2013 Unable to configure and get running. Program hangs. Configuration details: Dell XPS M1330 ; Intel Duo CPU ; T8300@2.4GHz; RAM 4 GB ; Windows 7; 32 Bit; SP1; Interface: RigTalk RT1-USB version of the Icom CT-17 Serial Interface; COM 5; Setting 19.2, 8N1N; Driver WMR, 21.07.2010, version 6.1.0.0; PROBLEM: IC7000BKT version 1.19.1; Run ic7000bkt_Setup.exe; Run IC7000BKT Icom CAT Control; Program Hangs, 8 bars in ’Initialization in process’ window; Status 5038; allow program another few minutes to initialize; can only close with ‘Task Manager’; RETRY: check port config, then RUN ic7000bkt_Setup.exe; Hangs the same; Status2037………….. Tried several times and get Status of 6293, 2060, 4025, ……………… De-Install 1.19.1; clear C: of IZ2BKT folder and its IC7000BKT Icom CAT Control; Re-Start PC Folder; Install version 1.14.2; Failure the same; Status 5039; ……………………… RETRY: check port config, then RUN ic7000bkt_Setup.exe; Hangs the same; Status2037………….. Tried several times and get Status of 6293, 2060, ……………… De-Install 1.14.2; clear C: of IZ2BKT and its IC7000BKT Icom CAT Control; Re-Start PC; Install version 1.19.1; Failure the same; ……………………… Other programs, Commander v 5.8.7 seem to function correctly. I am not aware of and appropriate reference program. Thanks for the assistance, Mike, HB9DHY Re: Installation and Configuration - iz2bkt - 02-04-2013 It seems to be a connection problem radio-> pc. Have you tried this: http://www.iz2bkt.com/forum/viewtopic.php?f=5&t=6, in particular tries to change from mode 1 to mode 2 or vice versa. The program must NOT be installed in "Program Files". Re: Installation and Configuration - iz2bkt - 02-06-2013 I recreated your condition and saw that the RigTalk has some problems, while trying to solve, use this configuration: Disable Polling, Configure COM: Mode 2, 19200,8,N,1 RTS=ON DTR=ON If you still have problems put the Latency to 200 or 300 (in the configuration window). Now I work to solve the problem with RigTalk. Re: Installation and Configuration - iz2bkt - 02-10-2013 Install version 1.19.2 |
