WSJTX Auto Grid Not Working
I have tried to get the Auto Grid to work with no results.  I have followed the directions from this post: https://www.maniaradio.it/forum/showthread.php?tid=569
     1.   I am running Windows 10 with the latest updates
     2.   I have installed .Net Framework 4.8.1
     3.   I have made sure the IP address and ports are correct in both BktTimeSynce and WSJTX along with the check boxes for auto grid
     4.   I have made sure that I have the GPS info including grid square before trying to push the auto
See attached pictures and the diagnostic log.
.txt   LogDiag.txt (Size: 22.83 KB / Downloads: 337)
the grid sent by BktTimeSync to WSJT-X will not be visible in the WSJT-X configuration but will be used only during transmission.
If WSJT-X is restarted, it must be sent again.
The log is correct.
