If a memory bank doesn't open, try these solutions:
.Close IC7100BKT
.Open RegEdit (press Windows+R, type RegEdit, and click OK)
.Go to the key: \HKEY_CURRENT_USER\Software\IZ2BKT\IC7100BKT
.Delete the key MemorieX (where X is the memory bank that is not opening, e.g., MemorieB for memory bank B).
.Close RegEdit.
If this doesn't work, try the following:
.Close IC7100BKT
.Navigate to the installation folder (usually C:\IZ2BKT\IC7100BKT Icom CAT Control)
.Delete the file MemX.Dat (where X is the memory bank that is not opening, e.g., MemB.Dat for memory bank B)
.Close IC7100BKT
.Close RegEdit.
.Close IC7100BKT
