Threads: 2
CallSign: VK2AAF
02-22-2023, 12:43 PM
(This post was last modified: 03-11-2023, 06:06 AM by iz2bkt.)
Hi Mauro
I received the key zip file
unzipped it in the C:\IZ2BKT\IC7000BKT Icom CAT Control folder
ran IC7000.bkt
found 'register program,' pointed it to VK2AAF.ic7000bkt.bkt
program responded that registration would work after program is restarted
restarted program
program knows my callsign but registered functions don't work, asks to register again
repeat repeat repeat
help please
thanks
Threads: 191
7
02-23-2023, 06:10 AM
(This post was last modified: 02-23-2023, 06:17 AM by iz2bkt.)
you are only registered for the Free version,
please reply to the registration email by attaching the IC7000BKT.INI file located in the C:\IZ2BKT\IC7000BKT Icom CAT Control folder
Thank you
Threads: 2
CallSign: VK2AAF
Hi Mauro
The FROM address on that email is noreply@maniaradio.it - will it go to you?
Thanks
Threads: 191
7
I received your email, the IC7000BKT.INI file seems corrupted, close IC7000BKT and delete the IC7000BKT.INI file, restart IC7000BKT, reconfigure the programme and reload the key.
Remember that the Free key expires after 30 days then some functions will be disabled.
Threads: 2
CallSign: VK2AAF
ok thanks, will try that
Thanks Mauro
CallSign: un7mbv
I received the full key. All problems with the trial version have been resolved.
Thanks for the great software.
In another thread I will write about the details that I would like to see in the program. Thank you.
