Guide to using IC7300BKT with WSJT-X or JTDX:
To start BktNetInterface with the CAT:
It is recommended to start IC7300BKT first and then JTDX or WSJT-X.
- Download and install BktNetInterface
- Start BktNetInterface
- Select the CAT in use (IC7300BKT)
- If you want the connection to start automatically when you open the program, check "Auto-start in system tray"
- Click "Start"
- Start JTDX or WSJT-X
- Go to "File" -> "Settings" -> "Radio"
- In "Rig" select "DX Lab Suite Commander"
- Close with "OK"
- Start IC7300BKT
- Go to "Utility" -> "Startup"
- In "Description" write "BktNetInterface"
- In "Program" select "BktNetInterface.exe" from the installation folder
- Click "Save"
