		11-17-2018, 11:49 AM
(This post was last modified: 11-18-2018, 02:48 PM by iz2bkt.)
		Hello, I just installed IC7000BKT, and when I try to start it for the first time, I get this error message: "Error in the initialization of the audio support, change the audio parameters?"  If I answer "yes", I get "Error in the initialization of the audio support" again.  If I answer no, nothing happens.  I run it on a PC with Windows 10 Home 64 bits.  How can I fix this?  Thank you.
Daniel VE2BAP, Canada.
	Threads: 191
8
		Hi Daniel,
go to in Utility->Configuration and click on Audio:....
Click on the button to the right of "Folder for audio files" and select a folder in documents, confirm by clicking OK and restart the program.
If you continue to receive audio error probably your PC's sound card is not compatible, you can disable audio support from Utility->Configuration -> Audio:.... and uncheck "Enable audio support"
