I have the CW & SSB filters installed in my 706Mk2G, the filter selection is made bad with the filter button,in cw modes the filter selected is W and never switch to the narrow filter.
The OP filter 1 is FL-101 and the Op filter 2 is FL-223
It's possible to solve this issue ??
Greetings
Jose
EA5SW
Threads: 191
7
The 706 does not have direct control on the filters, only option is 1(Wide) or 2(MEDIUM)
Hello again Mauro, I think that the forum database is restored.
Please remember the issue of the 3 filters settings:
<!-- m --><a class="postlink" href="http://www.plicht.de/ekki/civ/civ-p33.html">http://www.plicht.de/ekki/civ/civ-p33.html</a><!-- m -->
Threads: 191
7
Thanks for the info, but there are some problems:
1.It does not work with the IC-706 and IC-706MKII
2.The filters are used in many parts of the program and change the management it takes a long time
3-You're the only one who has requested this change, this means that it is little used
Solution:
In the next version there will be buttons can be customized with your own commands, you can use one of these keys to the narrow filter.
Many thanks Mauro !!
73 & DX !
Threads: 191
7
Hi Jose,
install version 4.18.0 of IC706_BKT, click the right button on a custom key and enter the command: 060302 for CW narrow
Just installed... hmm don't work...
EDIT: 060303 make the "trick"
Thanks Mauro
