09-30-2013, 02:22 PM
Tried to set an HF channel 7.215Mhz on LSB.
So I've got
VFO-A 7.215,000
Mode-A LSB
Filter-A Off
VFO-B 7.215,000
Mode-B LSB
Filter-B Off
Split NOSPLIT
DUP NODUP
Tone OFF
TSQL Off
Tone blank
Sync with the radio....but when I select the channel from the radio or through bkt is comes up FM.
If can select LSB from the bkt control panel...just doesn't work from memory chanells.
I'm on version 4.13.1
Mike W9MDB
So I've got
VFO-A 7.215,000
Mode-A LSB
Filter-A Off
VFO-B 7.215,000
Mode-B LSB
Filter-B Off
Split NOSPLIT
DUP NODUP
Tone OFF
TSQL Off
Tone blank
Mike W9MDB
