Hi!
Sorry for the delay in follow-up (family matters). I now have the Diagnostic Log Enabled.
From a 'Clean Boot' on Win7 [Dual XEON CPU each 4 Cores], using VCOM, BktTimeSync starts normally.
BTW: When BktTimeSynch starts There are 4 entries in the Event Log (App):
   First: Event #9010 {see detail below}
            Event #9013 {see detail below}
            Event #9010 {A request to disable the Desktop Window Manager was made by process (BktTimeSync)}
   Last: Event #9013 {The Desktop Window Manager was unable to start because composition was disabled by a running application}
After launching BktTimeSync, I do a few Manual Syncs & the delta-time looks fine.
On my system, BktTimeSynch normally runs with 7 Threads (I've seen 6-8).
*** I've not dug into the Restart issue because there seems to be a more critical issue!
** Approx 50% of the time (I tested about 20 times), when I close BktTimeSync from the GUI, the App closes, but the Process "BktTimeSync.exe *32" continues to run 4 Threads using 100% of one CPU core. The BktTimeSync Icon in the System Tray remains; but Right|Left Mouse clicks have no effect. **
Task Manager can kill the process in the usual way.
In the LogDiag.txt (after Killing the Process to get access to the log file); it begins:
Windows Versione: 5.01
BKTTimeSync Versione: 1.7.0
NTP Server: utcnist2.colorado.edu
NTP Porta: -1
NTP Offset:
NTP ON: 0
Autostart: -1
Start in tray: -1
Sync all'avvio: 0
Sync ogni: 30 minuti
Sync massima: 1 ore
GPS Porta: 3
GPS Baud: -1
GPS Bit: -1
GPS Bit di stop: -1
GPS Parità:
GPS RTS: -1
GPS DTR: -1
GPS Offset: 0.22
GPS Always Connected: 1
Sequence: 1
12/26/15 15:43:09 --> Sync start P1
12/26/15 15:43:09 --> Sync GPS COM open
12/26/15 15:43:10 --> Sync start P1
12/26/15 15:43:10 --> GPS rx str P1
12/26/15 15:43:10 --> GPS rx str: $GPRMC,224310.00,A,3434.93950,N,11227.96299,W,0.228,,261215,,,D*66
The Log ends:
12/26/15 15:43:18 --> 12/26/15 16:13:00Sync GPS OK, next to :
12/26/15 15:43:19 --> Sync start P1
12/26/15 15:43:19 --> GPS rx str P1
12/26/15 15:43:19 --> GPS rx str: $GPVTG,,T,,M,0.036,N,0.067,K,D*22
$GPGGA,224318.00,3434.93959,N,11227.96310,W,2,12,0.77,1639.6,M,-26.7,M,,0000*50
$GPGSA,A,3,32,31,14,26,11,03,23,51,01,22,46,25,1.47,0.77,1.25*06
$GPRMC,224319.00,A,3434.93956,N,11227.96315,W,0.136,,261215,,,D*60
$GPVTG,,T,,M,0.136,N,0.251,K,D*24
$GPGGA,224319.00,3434.93956,N,11227.96315,W,2,12,0.77,1639.6,M,-26.7,M,,0000*5B
12/26/15 15:43:19 --> GPS rx str: $GPGSA,A,3,32,31,14,26,11,03,23,51,01,22,46,25,1.47,0.77,1.25*06
12/26/15 15:43:20 --> GPS rx str P1
12/26/15 15:43:20 --> GPS rx str: $GPRMC,224320.00,A,3434.93955,N,11227.96317,W,0.099,,261215,,,D*6F
12/26/15 15:43:20 --> 12/26/15 16:13:00Sync GPS OK, next to :
HTH,
Roger
