Feature requests
Lightbulb
First of all, thank you for great application.
I have two suggestions:
1. Add a possibility to setting time difference in seconds manually. Like in TimeFudge.
It very simple but useful function if there aren't internet or gps available.
Something like:
[Image: TimeFudge-Scrn.png]
2. Add of functionality of really outstanding app BktTimeSync Phone to the BktTimeSync.
There are two bonuses of it step:
a) One fully functional app that's conforms all possible needs of time sync for ham purposes.
b) Absence of Java  Wink
You can correct the time difference using the Offset field
[Image: BktTimeSync_en_offset.png]
(03-21-2019, 07:31 AM)iz2bkt Wrote: Hi,
I don't understand how I must use "Offset" option in that (real) situatuation:
I'm in the middle of nowhere without internet access and some serious troubles with my gps equipment was occured (it doesn't work at all).
What should I do (step for step) for manual time correction in BktTimeSync to make QSO at digitial modes (ft8,jt65) possible?
Use the Windows command:
  • Open the command prompt in Administrator mode
  • Type TIME Hours: minutes: seconds (example TIME 10:42:25) and Enter
You Can keep the command prompt open, press the F3 key and repeat the operation as many times as you want
Lightbulb
(03-21-2019, 09:59 AM)iz2bkt Wrote: Use the Windows command:
Nice try, but no  Wink
It's almost impossible to set time offset (not new time) especially in milliseconds in such way.
Look, I don't talk about workarounds. I can invent a lot of them. For example on PowerShell:
Code:
$TimeDiff = Read-Host 'Input time difference is second (s.s)?'
$SrcTime = Get-Date -Format 'yyyy.MM.dd HH:mm:ss.fff'
$DstTime = Set-Date ((Get-Date).AddSeconds($TimeDiff)) | Get-Date -Format 'yyyy.MM.dd HH:mm:ss.fff'
Write-Host ("Src-Time = "+$SrcTime) -Foreground Yellow
Write-Host ("Dst-Time = "+$DstTime) -Foreground Green
I only want to say that it would be nice to implement such (very very simple) functional in BktTimeSync.
Thanks for the tip.
Hi
this is available from the BktTimeSync version 1.10.0
(04-11-2019, 08:04 AM)iz2bkt Wrote: Hi
Perfect! Thank you.
