Guide for using CatBkt with WSJT-X, JTDX, MSHV:
CatBkt Version 1.15.0 and later:
- In CatBkt go to Utilities -> Configure
- Enable LAN Protocol on port 52002
- Confirm with OK
In WSJT-X or JTDX:
- Go to File -> Settings -> Radio
- In Rig select DX Lab Suite Commander
- Confirm with OK
In MSHV:
- Go to Options -> Interface Control
- In the Network box -> Server type 127.0.0.1 and in Port type 52002
- In RIG select DX Lab Suite Commander
CatBkt versions prior to 1.15.0:
- Download and install BktNetInterface
- Start BktNetInterface
- Select the CAT in use (CatBkt)
- If you want the connection to start on opening check Auto-start in system tray
- Start with "Start"
In WSJT-X or JTDX:
- Confirm with OK
In MSHV:
To start BktNetInterface together with the CAT (only versions before 1.15.0):
- Start CatBkt
- Go to "Utilities" -> "Startup"
- In "Description" write "BktNetInterface"
- In "Program" select "BktNetInterface.exe" from its installation folder
- Click on "Save"
It is advisable to start CatBkt first and then JTDX, WSJT-X or MSHV
- Confirm with OK
In WSJT-X or JTDX:
- Confirm with OK
In MSHV:
In WSJT-X or JTDX:
- Confirm with OK
In MSHV:
- Start CatBkt
- Click on "Save"
