bktimesync locking up
#11
(11-10-2017, 07:07 PM)krutzy Wrote:  bktimesync locks up after initial synchronization
Same problem here. USB GPS receiver(G7020 chip) working fine with other applications. BKTtimesync working fine with NPT server but not working together. Not answering but using CPU abt 30%. (32-bit Win10 1.3GHz). Same v1.9 or 1.10 How to fix it?
#12
I'm sorry but I don't have a solution for this yet.
#13
(04-21-2019, 09:09 AM)iz2bkt Wrote: I'm sorry but I don't have a solution for this yet.
It seems that the buffer is filled with data from the GPS. The work of the program gradually slows down and then stops.
#14
Please try BktTimeSync version 1.11.0
#15
all the same, sorry
#16
Please enable the diagnostic log and post the result
#17
(04-23-2019, 05:07 AM)iz2bkt Wrote: Please enable the diagnostic log and post the result
Log attached
.txt   LogDiag.txt (Size: 13.12 KB / Downloads: 473)
#18
Thank you.
Try to set the sync every 60 minutes, if it doesn't work, activate "Alway connected to the GPS"
#19
(04-23-2019, 07:06 AM)iz2bkt Wrote: Thank you.
"Alway connected to the GPS" it's fix a problem. Thank you!
