Scan resume Icom Ic-700
When useing the scanner on BKT, when stop the software defaults the radios menu #28 (set mode, other, #28 ) to off. I am thinking a option to default the setting on/off when exit. This really isn't a big issue unless using radio on scan with out BKT back and forth. Then this must be reset every time.
Thank you for being you and letting me be me - KC7IDO - Mike
