This app stopped working when my phone updated to Android 10. It showed my locator and coordinates but was not able to sync the time. I reinstalled and after it the compatibilty test started and the result is - my GPS receiver is not compatible with NMEA any more. Does anybody else have the same problem?
BktTimeSyncAndroid on Android 10 - SOLVED
07-07-2020, 05:55 AM
Hi, probably the update has changed the GPS protocol and is no longer compatible with the NMEA standard
07-13-2020, 04:06 PM
(07-07-2020, 05:55 AM)iz2bkt Wrote: Hi, probably the update has changed the GPS protocol and is no longer compatible with the NMEA standardHi Mauro, I am sorry for the mess - I suppose you moved my post here from the wrong place. Pls, are you going to update the Android app? Am I not the only one user, ![]() Tnx de Miloš, OK1FMY
07-13-2020, 04:13 PM
Hi Miloš,
I tried it myself on Android 10 and it works, this message is also given on non-Android 10 smartphones that do not allow you to read GPS in detail but only to display the coordinates and therefore do not go well.
07-13-2020, 05:41 PM
(07-13-2020, 04:13 PM)iz2bkt Wrote: Hi Miloš,Hi Mauro, my phone is Huawei Mate 10 Pro. It is a model they released before the "divorce" with Google. The app worked fine on the phone with Android 9. It stopped working after the update. Can I get more info from my phone? Tnx, Miloš
07-18-2020, 01:13 PM
Hi Miloš,
I published in the Google Play Store BktTimeSyncAndroid version 1.1.0 which improves compatibility with Android 10, I hope it solves your problem. Remember that updates on the Play Store are not distributed simultaneously for all states, it could be that you arrive on a different date from today, check the updates of the Apps.
07-19-2020, 04:20 PM
(07-18-2020, 01:13 PM)iz2bkt Wrote: Hi Miloš,Hi Mauro, I updated the app and it works again - mni tnx. 73! de Miloš |
« Next Oldest | Next Newest »
