03-07-2011, 08:03 PM
Good Afternoon,
I'm a quadriplegic who was referred to your software by someone at Ham Radio Deluxe, because your software can change tones for T-SQL, and HRD cannot. BKT allows more control via computer (CAT control).
For some reason, when I loaded it, I cannot connect and I'm forced to Offline Mode and therefore cannot change ports to try; but HRD works fine on Com 5, the com port I'm using. HRD is not open though.
Also, the little box that comes up when I first installed BKT7000 where I set the ports/speed no longer comes up. It just says Com5 isn't working, exit or work offline. How can I change them now?
My system is a Dell Laptop, with a CI-V cable that has both ACC plug and 1/8" plug for the radio (I have to unplug the ACC and only use the 1/8" for HRD).
73,
Keith W5KTT
73,
Keith W5KTT
