Display of Maidenhead Grid Locator on BKT Time Sync screen - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: BktTimeSync (https://www.maniaradio.it/forum/forumdisplay.php?fid=28) +--- Forum: BktTimeSync (https://www.maniaradio.it/forum/forumdisplay.php?fid=22) +--- Thread: Display of Maidenhead Grid Locator on BKT Time Sync screen (/showthread.php?tid=96) |
Display of Maidenhead Grid Locator on BKT Time Sync screen - W7GJ - 10-29-2012 Since you are already reading the NMEA data streams to obtain the time from the GPS unit, it would be very convenient if you could also simply display the Maidenhead Grid Locator when the GPS receiver is being used. It also would be great if you could add an option for faster BAUD speeds....my GPS receiver and USB ports can work at 115,200 Baud. MNI TNX and VY 73, Lance Re: Display of Maidenhead Grid Locator on BKT Time Sync scre - iz2bkt - 10-30-2012 W7GJ Wrote:Since you are already reading the NMEA data streams to obtain the time from the GPS unit, it would be very convenient if you could also simply display the Maidenhead Grid Locator when the GPS receiver is being used. Hi Lance, Thank you for your input, if possible, will be integrated in the next version. Re: Display of Maidenhead Grid Locator on BKT Time Sync scre - W7GJ - 10-30-2012 MNI TNX for your consideration! I look forward to hearing about the release of the next version! VY 73, Lance |
