How to localize the program - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: IC706_BKT Cat Control for Icom IC-706 (https://www.maniaradio.it/forum/forumdisplay.php?fid=3) +--- Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=4) +--- Thread: How to localize the program (/showthread.php?tid=82) |
How to localize the program - iz2bkt - 05-26-2012 How to localize the program: 1. Go into install folder ( Ex. C:\IZ2BKT\IC706_BKT Icom CAT Control ) 2. Copy the files english.lng to a new file .lng (Ex. spanish.lng) 3. Run BKTLocalize (https://www.maniaradio.it/dati/BKTLocalize.zip) 4. Select the new file created in step 2 5. In the right column write the translated text or leave blank to not translate 6. Save the file by pressing Save and Close 7. Run IC706_BKT Icom CAT Control 8. In TAB Utility select Configure 9. Click on the Change Language button and select the new language IMPORTANT: . Do not change the special characters that begin with % or \ . Translated sentences should not be longer than the original Send me the translated file if you want to share it with others users. |
