How to localize the program - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: IC7000BKT Cat Control for Icom IC-7000 (https://www.maniaradio.it/forum/forumdisplay.php?fid=5) +--- Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=7) +--- Thread: How to localize the program (/showthread.php?tid=81) |
How to localize the program - iz2bkt - 05-26-2012 How to localize the program: 1. Go into install folder ( Ex. C:\IZ2BKT\IC7000BKT Icom CAT Control ) 2. Copy the files english.lng to a new file .lng (Ex. spanish.lng) 3. Run BKTLocalize (https://www.maniaradio.it/dati/BKTLocalize.zip) 4. Select the new file created in step 2 5. In the right column write the translated text or leave blank to not translate 6. Save the file by pressing Save and Close 7. Run IC7000BKT Icom CAT Control 8. In TAB Utility select Configure 9. Click on the Change Language button and select the new language IMPORTANT: . Do not change the special characters that begin with % or \ . Translated sentences should not be longer than the original Send me the translated file if you want to share it with others users. |
