ERROR WHILE TRYING TO PROGRAM MEMORY BANK - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: IC7000BKT Cat Control for Icom IC-7000 (https://www.maniaradio.it/forum/forumdisplay.php?fid=5) +--- Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=7) +--- Thread: ERROR WHILE TRYING TO PROGRAM MEMORY BANK (/showthread.php?tid=8) |
ERROR WHILE TRYING TO PROGRAM MEMORY BANK - K2OMN - 10-09-2010 Greetings, I guess the primary problem is when I try to either read in the band limits it does so incorrectly. I try to input the band limits manually and it saves them ok. However, when I try to save a memory I'm manually entering it give me an error "The RX and TX are out of limits..." I even ensured that the band limits were set correctly on the drop down menu. Although I can still save my data and upload it to the IC-7000 the error message is an issue. Any thoughts about this error message and how I can resolve it? I really like this software pacakge, its quite functional and elegant in design although I can't figure out how to manually change frequency channels using the panel. Thanks and 73, Joe Re: ERROR WHILE TRYING TO PROGRAM MEMORY BANK - iz2bkt - 10-10-2010 K2OMN Wrote:Greetings, Hi Joe, the bands and mode limits are not used in memory input, be careful to enter the frequency in Hz, example to insert 145.562MHz you'd write 145562000. 73 de Mauro, IZ2BKT |
