BktTimeSync v1.20.xx (SOLVED) - Printable Version
+-- Forum: BktTimeSync (https://www.maniaradio.it/forum/forumdisplay.php?fid=28)
+--- Forum: BktTimeSync (https://www.maniaradio.it/forum/forumdisplay.php?fid=22)
+--- Thread: BktTimeSync v1.20.xx (SOLVED) (/showthread.php?tid=642)
BktTimeSync v1.20.xx (SOLVED) - Brad Williams - 05-27-2025
Hi Mauro,
I've been using BktTimeSync for quite some time.  Current working version is v1.15.0.  I installed v1.20.0 and the GPS sync did not work and gave a "GPS time invalid".  I then tried the latest v1.20.1 and still got "GPS time not valid".  I tried uninstalling v1.15.0 and installing v1.20.1 but get the same issue.  Disconnecting the GPS and re-connecting did not resolve the issue.
Any thoughts ??
PS: Running Windows 10Pro
Thanks,
Brad, K8ZM
RE: BktTimeSync v1.20.xx - iz2bkt - 05-27-2025
Hi Brad,
With BktTimeSync version 1.20.1, please try enabling diagnostic log, perform a sync, and then attach the log here.
Thanks.
RE: BktTimeSync v1.20.xx - Brad Williams - 05-30-2025
iz2bkt Wrote:Hi Brad,
Thanks.
Here is the logfile.
Brad, K8ZXM
Thanks.
Brad, K8ZXM
RE: BktTimeSync v1.20.xx - iz2bkt - 05-30-2025
Hi Brad,
thanks for the log.
Try installing BktTimeSync version 1.20.2. If you still have problems, please send me the diagnostic log from 1.20.2.
Thanks for your cooperation.
Thanks Mauro,
SOLVED - 1.20.2 seems to work fine !! I'll report back if any issues but all looks good !!
Thanks again for the quick fix !!!
73, Brad K8ZM
