IC706_BKT configuration page, and getting started - Printable Version
+-- Forum: IC706_BKT Cat Control for Icom IC-706 (https://www.maniaradio.it/forum/forumdisplay.php?fid=3)
+--- Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=4)
+--- Thread: IC706_BKT configuration page, and getting started (/showthread.php?tid=597)
IC706_BKT configuration page, and getting started - wa1rkt - 02-15-2024
Good afternoon from snowy New Hampshire, USA.
Just getting started with IC706_BKT and so far have not been able to get it to work.
I need an Icom CT-17 or equivalent cable, right?  I have the LCU3-I and OPC-478 cables and they don't work, so I assume I need to get a CT-17 equivalent cable, right?
Second question... how do I get back to the IC-706_BKT configuration page?  When I first started it up it took me to the config page but since then it just takes me to the main page and I can't change the configuration.  I assume there is something I click to take me to the configuration but I don't see it.
The defaults are 19200-8-N-1, RTS and DTR both ON.  Is that the correct configuration to talk to the IC-706MKIIG?
Thanks...
Rick WA1RKT
Londonderry, NH, USA
Catch me on 14.300 MHz Intercon / MMSN most days
RE: IC706_BKT configuration page, and getting started - iz2bkt - 02-16-2024
Hi Rick,
For the interface, search on eBay for 'ci-v for icom ic-706.' I can't tell you which ones are the best.
To open the configuration page, go to Utility -> Configuration.
For further information, you can consult the PDF manual by downloading it from https://www.maniaradio.it/en/ic706bkt3en_download.html or press the F1 key when you are in the program.
RE: IC706_BKT configuration page, and getting started - wa1rkt - 02-18-2024
Ordered one of these...
https://www.ebay.com/itm/155850473933
When it gets here will report back on results.
Rick WA1RKT
RE: IC706_BKT configuration page, and getting started - wa1rkt - 02-22-2024
Received the BlueMax49ers CT-17 CI-V cable from bluemax49ers.com and it works reasonably well. I was able to program most of the 99 memories in the 706 within the known limitations. Had to manually program all the PL tones but I knew I'd have to do that... it was a bit of a pain but not too bad. I can program the repeater inputs to VFO B and outputs to VFO A and set "SPLIT", all within the program. So, it works well enough for my needs, and as we know, the limitations aren't anything Mauro can do anything about.
I see that there doesn't appear to be an equivalent program available for the IC-746Pro, is that right?
I also see, however, that there IS one for the IC-7300. I'll try that and report back (in the IC-7300 forum).
Thanks, Mauro.
Rick WA1RKT
RE: IC706_BKT configuration page, and getting started - iz2bkt - 02-23-2024
Thank you, Rick, for sharing your tests.
